First post, by Nicht Sehr Gut
Has anyone ever come across a hard disk (partition) that crashed, then wasn't recognized as valid by the BIOS upon the reboot. If so, did you get the same results as I did when I ran dianostics on it: Nothing?
I scanned, performed virus-checks, re-installed the MBR, everything. Nothing helped until I re-formatted. Worked fine after that. Odd.
Reply 2 of 4, by Stiletto
This shouldn't be in Deep Thought. Moved.
do the Fandango!" - Queen
Stiletto
Reply 3 of 4, by Nicht Sehr Gut
Eh? I was in Millyways. How'd it get into Deep Thought?
Reply 4 of 4, by Nicht Sehr Gut
DosFreak wrote:
How did you fix the MBR?
Well since it was a dual-boot, I tried a re-installing the MBR for both. 1st , Win98; then XP (I figured XP would be safer to perform as XP "knows" 98, but 98 does not "know" XP). Neither worked.
One thing I forgot, Partition Magic (floppy version) detected that the XP partition was "improperly dismounted". Unfortunately I had no tools that could correct that.
Were the boot files NTLDR,NTDETECT.COM (NT) or MSDOS.SYS,IO.SYS,COMMAND.COM (Dos) on the primary partition?
Actually, they're all there since I'm using a Dual-Boot.
