First post, by Beylie
I've been using DOSBox for some time now and decided to try it on my phone too. I've downloaded DOSBox Manager, but would like to know if there's not a way to import existing .conf files? I see by default they're created in my external_SD/Download folder when adding a new one via DOSBox Manager, but copying existing .conf files to that folder does not make them show up in DOSBox Manager. I've also noticed that even if I delete the .conf files from the Download folder, they still appear in DOSBox Manager and is just recreated in the Download folder when they're run again. I cannot find any other location where these .conf files might be kept so I can attempt a bulk import of .conf files.
Any advice?
EDIT:
I've read this article http://www.dosbox.com/wiki/Dosbox.conf, but it does not contain what I'm looking for.
Reply 2 of 2, by Beylie
Thank you for the prompt feedback.
