First post, by dogchainx
I have a few dead pieces of hardware (a bunch of 386 motherboards, an orchid vga card, etc).
Do you guys just toss it/recycle them, or does anyone here have any use for them....maybe fixing them? (the orchid card needs its video signal processor reattached...bunch of pads missing, etc).
Seems like a waste to just toss them if its just a capacitor somewhere that needs to be replaced.
386DX-40MHz-8MB-540MB+428MB+Speedstar64@2MB+SoundBlaster Pro+MT-32/MKII
486DX2-66Mhz-16MB-4.3GB+SpeedStar64 VLB DRAM 2MB+AWE32/SB16+SCB-55
MY BLOG RETRO PC BLOG: https://bitbyted.wordpress.com/
Reply 1 of 11, by Caluser2000
Some folk keep them to scavenge parts off of.
Reply 5 of 11, by Unknown_K
I keep things that are repairable for when I need them and a replacement will cost too much. Some things just need capacitor replacements, broken tracks fixed, maybe a common part replaced. Anything that needs major work gets recycled (like an 880W gamer PS with multiple blown parts).
Reply 6 of 11, by shock__
Would have been my answer as well ... or repair minor/costeffective damages.
Current Project: new GUS PnP compatible soundcard
[Z?]
Reply 7 of 11, by PeterLI
I throw broken equipment out.
Reply 8 of 11, by alexanrs
Depending on the equipment I, in the first place, mourn it... put it inside a drawer or not-so-exposed shelf on my wardrobe hoping I'll find some use for it, then after some time take it out and study if it is beyond repair and, if it is, put it on a high shelf in my room telling myself I'll eventually throw it out and, once in a blue moon, I actually do it. I think I had a broken AGP 6800 for two years (one day it refused to work, and putting a higher capacity PSU on the PC only allowed a capacitor to literally explode) before I finally threw it out.
Reply 9 of 11, by Jorpho
I've managed to eBay some dead parts in the past (with full disclosure, to be sure). It takes a while, though.
Reply 10 of 11, by kolano
One good use is crafts artwork. I have an Macintosh SE lamp for instance, and another one I want to make a fishtank from eventually (need to find or make an appropriately sized tank). Have also used old RAM sims as key fobs.
Eyecandy: Turn your computer into an expensive lava lamp.
Reply 11 of 11, by Robin4
I always try to repair them.. if possible.. If the damage is to much i would remove the usefull parts from the PCB, the blank empty pcb i would dump..
