First post, by DoomGuy II
I'm just curious to see if I can be able to play a video game with sound while having WinAmp play music in the background using an ISA sound card. I have a Sound Blaster 16 installed and obviously it can't be accomplished on that card. I also have a YMF-719 installed and while I can have one sound card play music and the other for game sound, I want to see if I can be able to do both on one card. Any thoughts?
Official Website: https://dg410.duckdns.org/
Reply 1 of 7, by jwt27
Any sound card can do this. Under Windows, the audio streams are mixed in software, unless one application takes exclusive control of the sound card.
Reply 2 of 7, by DoomGuy II
jwt27 wrote:
...unless one application takes exclusive control of the sound card.
I think that's the problem I'm trying to solve. Wasn't exactly thinking this through properly since I want to see if there is any way I can play a video game with sound while having WinAmp play music in the background using an ISA sound card.
Reply 3 of 7, by kixs
Yes, you can.
Reply 4 of 7, by jwt27
In Windows 7 there's a checkbox named "allow applications to take exclusive control of this device", under the sound card options. I believe earlier Windows have this option too, but I don't recall where it's located. I'd suggest looking around in the control panel.
Reply 5 of 7, by kixs
Yes, you can.
I guess you are trying this on Win95 or 98? You have to use SB16 drivers with DirectX support. You should be able to do what you want with it. Also use DirectX out in WinAMP.
Try this ones:
http://files.mpoli.fi/hardware/SOUND/CLABS/SBW95UP.EXE
Reply 6 of 7, by feipoa
Set the sound output in Winamp to use DirectSound instead of wavout. This is what worked for me on my 486.
Reply 7 of 7, by leileilol
That can't work if it's DOS games he'll be playing with. It won't be able to initialize sound.
jwt27 wrote:
In Windows 7
if one has ISA, they're going to be pretty damn far away from using Windows 7...
