First post, by MrEWhite
So I recently acquired a Gateway 2000 P5 120, I get an error saying "CMOS Battery Failed" So how would I remove the battery and where would I buy a replacement?
Here's some pictures:
Reply 1 of 11, by alexanrs
You should be able to get a CR232 just about anywhere. They are REALLY easy to find, and any PC/eletronics shop should have it. Also, I don't see anything exotic about the battery holder, taking it out should be simple enough, you might just need something like a very small screwdriver to help you remove it. There usually is a small "locking mechanism" you have to pull/pry to get it off... I'd guess it's that bigger thing above the 3V text on the battery.
Reply 2 of 11, by MrEWhite
Those do nothing, or I cant do nothing. Any other way of removing it?
Reply 3 of 11, by alexanrs
I'd just pry the battery with a small screwdriver... maybe while bending those plastic "locks". Just make sure you're not in a hurry or putting too much force. Last thing you want is for the screwdriver to slip and scratch something.
Reply 5 of 11, by sirlemonhead
I have the Gateway P5-75. It uses a CR232. It's very easy to remove.. I thiiink you have to push on one side of the battery with a screwdrive to slide and pop it out from under a little shelf that holds it down. It's simple, anyway.
Edit: Scratch that.. I'm not 100% sure. I assumed the Rayovac wasn't a coin shaped battery without checking that link first. I'm fairly sure I replaced it with a CR232, though, and it works..
Reply 6 of 11, by MrEWhite
It is a CR232, any idea where I can obtain one?
Reply 8 of 11, by alexanrs
Yes, these are fine, but you can also find this in any PC and eletronics store in the world. These batteries are very common... I wouldn't be surprised to find them in a supermarket or something like that.
Reply 9 of 11, by ODwilly
Usually around $5 in any pharmacy or supermarket type of store.
Reply 10 of 11, by MrEWhite
Also, unrelated but is there a way to stop the front from coming off? Because the 2\4 plastic things that held the front cover to the case are gone and 1 of those two are detached. Could I just glue one of the plastic thing to its original spot?
Reply 11 of 11, by alexanrs
If you still have them, I think it should be okay. But you'll need some strong glue (like epoxy glue) or else it won't hold for long.
