First post, by JUB1L
I have Dosbox and the DOS programs in a directory on a Synology NAS drive. The combination works fine if I map the drives to letters Y and Z but I have do this every time before I can use Dosbox. I cannot mount the drives either by their network names or IP addresses presumably due to the 8.3 dos filename limitation (eg 192.168.1.3 or SynologyDrive1). If I were to start with 2 new discs and call them X and Y with sub directory \test containing the DOS files, would they be recognised using:-
mount C X:\test
C:
or is there another simple way round this problem please?
