First post, by Chaniyth
So I recently picked up 2 VESA Local Bus graphic cards. One is a S3 805 [not really sure of the cards brand] the other is a S3 Trio64 [Paradise Bahamas64 brand?].
I've not fully tried out the S3 805 yet except to see if it works however I've been using the S3 Trio64 a lot since I received both cards yesterday.
On the Trio64 I'm experiencing really bad "rainbowing" issues with all Build engine games. For non-Build engine games some times the "rainbowing" will show up in game videos but not always. Every other game I've tried looks great though.
The motherboard is an M919 v3.4B/F , no cache ram stick (misplaced the darn thing somewhere), AMD AM5x86 CPU, 24mb ram. This motherboard is only for testing the VLB boards. I'll be replacong it and using a Gigabyte GA-486VS motherboard as so as it arrives.
Any ideas what is causing the "rainbowing" colors for Build engine games and certain videos/games but not others? Is there a fix?
Thanks in advance. 😎
All the world will be your enemy, Prince with a Thousand Enemies, and when they catch you, they will kill you... but first they must catch you. 😁
Reply 1 of 18, by Stojke
Im pretty sure thats memorry issues.
I had the same problem with one Voodoo 1 MX card.
Reply 3 of 18, by Chaniyth
Anonymous Coward wrote:
What bus speed are you running?
Good question, I'm not sure so I'll have to check in a bit. I know the AMD AM5x86-P75 is running at its default speed of 133Mhz so I'm assuming a 33mhz bus speed.
Reply 4 of 18, by Chaniyth
I been thinking that to but if it were wouldn't all games look messed up? Tombraider, Quake, etc 3D games look just fine, 2D games also look fine. I'm not sure how many megs of ram the cards have, I know there's 2 chip sockets that are empty on the board.
Reply 5 of 18, by Stojke
Same happened to me. Some times works fine, some times awesome rainbow of death.
Might be a cold solder joint.
Reply 6 of 18, by Chaniyth
So I just tried Build engine games with the S3 805 VLB card and the same issue, really weird for 2 separate VLB graphic card to have the same issue, so I'm thinking the problem may be in the M919 motherboard (it's a PCChips motherboard) or possibly its VLB slot is bad.
I checked for cold solder joints on the cards and everything looks fine.
Guess I'll know for sure once the Gigabyte GA-486VS motherboard comes. I really hope it's not the VLB cards.
Reply 7 of 18, by alexanrs
Have you tried underclocking the FSB? It's PCChips so I wouldn't be surprised if it is finnicky even when not using high bus speeds.
Reply 8 of 18, by Chaniyth
Not yet. I might not tinker with that motherboard anymore since I'm expecting a better one soon, and will test those VLB graphic cards on it, hopefully successfully without them doing that weird rainbow of colors.
Reply 9 of 18, by Anonymous Coward
I have a Hercules Terminator 64 DRAM VLB based on Trio64 that also has funny colours *sometimes*. I assumed it was bad memory, but maybe the IC is bad somehow. It was the first S3 product with an integrated RAMDAC, so who knows.
Reply 10 of 18, by Chaniyth
Just a quick follow up. The Gigabyte GA-486VS board arrived today and the S3 Trio64 VLB and S3 805 VLB cards are working just fine and great without any rainbowing effect! Rocking Duke Nukem 3D, Shadow Warrior, etc like a boss! 😎
So the culprit was definitely that piece of crap PCChips M919 v3.4B/F motherboard. Blech! 😵
Reply 11 of 18, by Robin4
Which 486 processor are you using?
Reply 12 of 18, by Chaniyth
Currently an Intel 486DX4-100 in that M919 I was using an AMD AM5x86-P75
Reply 13 of 18, by kixs
Can you do some performance comparison between Trio64 and 805? I'd like to see Phil's benchmark suit done on the same platform but with different graphic cards. If possible also Windows 3.11 or Windows 95 with Winbench 3.11 and Wintach 1.0 - when and if you find the time 😉
Reply 14 of 18, by Chaniyth
I'll see what I can do, however I can tell just by eyeballing it, the S3 Trio64 VLB board is faster than the S3 805 VLB board in DOS, i'll have to try out Windows 3.11 WFW but i'll assume the same can be said for it as well.
Reply 15 of 18, by Chaniyth
Ok here's what I pulled from Speedsys.
S3 805 VLB 1MB - 4780 KB/s
The attachment 20150326_113427.png is no longer available
S3 Trio64 VLB 1MB - 17841 KB/s
The attachment 20150326_114156.png is no longer available
Reply 16 of 18, by kixs
Thanks for the Speedsys... now I'm really interested in Windows performance as my VLB Tseng w32 has the same VESA speed and I believe Trio64 is the last gen VLB graphic card.
Reply 17 of 18, by Cga.8086
i have the very same problem with the m919 and the amd P75 (133mhz) cpu. with a trident card Vesa
everything looks ok,untill i run doom, the title menu and gaming looks with different colors. like inverted but the colors are all different
i tried lowering the mhz to 100mhz and got the same result.
i tried the card on another motherboard with a dx2 66mhz and the card works perfectly
i dont know what is the issue on M919, maybe a bios setting? or jumper setting i dont think so
Reply 18 of 18, by Anonymous Coward
The problem with my Trio64 VLB card (Hercules Terminator 64/DRAM) turned out to be cold solder joints, not a motherboard issue. Your issue is likely the M919. PCchips sucks!
