First post, by Roman78
I'm running w2k on a HP Thin Client. Now I installed a 24" display whit a resolution of 1920x1080. But I can't chose that resolution. First I would say... not supported, but than I found even higher resolutions like 1920x1200 and some 20something by14something. The onboard graphic card I use is a SIS Mirage.
So is there a simple way to set the resolution to the right one? Could not find anything for w2k....
Reply 2 of 4, by Lo Wang
Just because a higher resolution is listed doesn't actually mean it's available. There's a lot of bad, messed up, generic drivers designed for different video card models and that could be just what you're seeing. However, if you can indeed set these higher resolutions, as DosFreak stated, PowerStrip is something to try, but I wouldn't put too much stock on it as it's really not all that useful for video cards past the GF6/7 series and other contemporary video hardware.
"That if thou shalt confess with thy mouth the Lord Jesus, and shalt believe in thine heart that God hath raised him from the dead, thou shalt be saved" - Romans 10:9
Reply 3 of 4, by leileilol
Some cards 'support' reses that high but can't output it. Like Rage128 for example can do a 1920x1080 desktop....cropped to 1280x1024 despite the monitor supporting 1920x1080
(in my experience)
long live PCem
Debian's fucked
Reply 4 of 4, by calvin
Also depends on OS. I got my Rage Pro to cough out 1680x1050 perfectly, but only on Linux. On Windows, I have to use 4:3 resolutions.
2xP2 450, 512 MB SDR, V3 2000, Asus P2B-D, Windows 2000
P4 2.6, 2 GB DDR1, Radeon 9600 Pro, P4P800, Windows XP
Alpha 21164, 512 MB, Permedia 2, KZPCM, AlphaPC 164, NT 4.0
