First post, by Chaniyth
http://www.theregister.co.uk/2015/03/19/canse … lk_bioses_hack/
As far as I can tell this is a "user end" only thing, but still it's an interesting read.
All the world will be your enemy, Prince with a Thousand Enemies, and when they catch you, they will kill you... but first they must catch you. 😁
Reply 1 of 11, by eL_PuSHeR
Nice reading.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 2 of 11, by mr_bigmouth_502
The way I see it, if you allow a potential attacker physical access to your system, you aren't doing your job correctly. 😉
Of course, what if you disabled onboard Ethernet from your BIOS, then put a password on it? Surely that could ward off some attackers, but some would just disassemble the laptop, look for the CMOS battery, and reset things to factory defaults. 🤣
Reply 3 of 11, by smeezekitty
Basically once an attacker has physical access, it's all over anyway.
When I saw both the OP and el_PuSHeR have the Simpsons (or something like it) avatars, it left be confused for a good 5-10 seconds
Reply 4 of 11, by sliderider
Exactly. A hacker can get what he wants from your computer in about 30 seconds by taking the case cover off, yanking your hard drive, then taking it with him to scan at his leisure if he manages to get in physical proximity.
Reply 5 of 11, by smeezekitty
The defense against physical access is full disk encryption which is not without downsides.
And even that isn't foolproof.
Reply 6 of 11, by eL_PuSHeR
It's up to mainboards manufacturers to patch up their lousy bios code.
Intel i7 5960X
8 GB DDR4 (2100)
Reply 7 of 11, by Caluser2000
It's up to the end user to secure there own systems from abuse. Games over once you give your system to someone else.
Reply 8 of 11, by leileilol
Well...there is physical self-defense 😀
long live PCem
FUCK "AI"
Reply 9 of 11, by smeezekitty
That too 🤣
Reply 10 of 11, by sliderider
Most motherboard manufacturers' websites do maintain databases containing all of their BIOS updates, but they don't do anything if people don't use them. Part of the problem, I think, is that they frequently tell you in the motherboard manual NOT to download BIOS updates unless you are experiencing problems and someone from tech support tells you to. Too many people seem not to have the proper skills to do a BIOS flash correctly and end up bricking their motherboards which leads to more calls to tech support.
Reply 11 of 11, by mr_bigmouth_502
Only helps if you get to them before they manage to compromise your system. 🤣
