First post, by filipetolhuizen
- Oldbie
Hello,
This very old computer was laying around with no use on our old flat for over 20 years. So I decided to hook it up and see what happened. To my surprise, everything was intact. It can be hooked up to any TV, has a Z-80 CPU @ 2MHz, 48k RAM and shows monochrome display only in black and white, no grayscale tones. This computer was manufactured by brazilian company Prologica in 1981. I'm using an iPad as a tape recorder to load the games in .wav files. Everything except for the PSU is inside the keyboard.
The iPad or whatever is used as the tape recorder, goes in the plug on the black cable. The original tape recorder has all the 3 plugs for them. They are: Data In, Data Out and Remote.
The CP-300 initial screen. Appears immediately when turning it on. No boot sequence is seen.
Playing Armored Patrol 3D.
So simple and fun! 😀
