First post, by rick6
I've gathered a few parts that could make a nice 1999 computer. I have a Pentium 3 733 and a 800 Mhz CPU, a Voodoo 3 3000 AGP video card, a Geforce 256 SDR and a DDR version, a 20GB IDE Seagate harddrive and a board to go with it. I'm missing a proper case and power supply though.
I need to recap the motherboard which is a ESC board with some via chipset. I know it's not great, but it's what i have so far.
Bare in mind it doesn't need to be a beast of a computer, just a nice and fluid gaming computer.
Mostly the games i'm planning to play on it are Quake 3 Arena, Unreal and Unreal Tournament with a great load of mods and costum maps all running at 1024x768 on some 17" CRT monitor.
My 2001 gaming beast in all it's "Pentium 4 Williamate" Glory!
Reply 1 of 28, by leileilol
A SBLive is fine too
BTW Voodoo3's a host card, you cant' have both the gf256 AGP and V3 AGP at once. V3 is definitely capable of 1024x768 gaming though
The advantages of the Geforce256 didn't really come to heavy use until late 2000, so for 1999 gaming it doesn't leave a lot of relevance (except for some Q3 benchmarks and yes it does smoke the V3 in a lot of them, but it's not a card to use over V3 if you're going to play UE1 stuff. It was mostly an expensive luxury item).
Reply 2 of 28, by rick6
I think i can get a SBLive too.
As for the Voodoo3 i was already a bit inclined to use it instead of the Geforce 256 for sentimental reasons, and also because i can use Glide for the unreal1 engine based games.
I'm not sure about the power supply but that's one bit i might skip when it comes to "time accurate components" and get instead a modern one for safety reasons.
Reply 3 of 28, by HighTreason
I have a machine from around that era that would have effectively been upgraded. Assuming cost isn't a factor, I'd just modify the spec list for that.
At present it features;
> SuperMicro P6DGU Motherboard
> 2 x 1000MHz PIII SL4BS
> 2GB PC133 SDRAM
> 2 x 18GB Quantum Atlas SCSI-2 HDDs
> 2 x 40GB IDE Drives (Maxtor or Nikimi, can't remember)
> ATI Radeon VE
> Sound Blaster AWE64
> Hauppague WinTV
> Pioneer DVD-RW
> Generic 430W PSU
To be relevant to 1999 I would make the following alterations;
> Replace GPU with GeForce 256
> Replace CPUs with 750MHz models (To get a head start saving for faster ones two years later. Today I'd just shove 800MHz ones in)
> Can't remember if 40GB drives actually existed in 1999, maybe those would be different
> If a lack of EAX or whatever ever bothered me, I would pair the AWE64 with a card that supported it as I like being able to drop back to DOS. I had a DOS compatible audio card in my PC right up until 2009!
Reply 5 of 28, by swaaye
Instead of a Live, I would find a Vortex 2-based card or a Philips Seismic Edge / Acoustic Edge (Thunderbird Avenger). Vortex 2 effectively doesn't support EAX but you get the only good A3D implementation. The Thunderbird chip is a hardware QSound implementation (which supports EAX) and is quite nifty if I might say so. Both do headphone/2 speaker vastly better than Live.
My appreciation of SBLive is pretty low these days because of noisy output that's annoying with headphones and frankly doesn't sound that great in general, and software/hardware stability issues. Audigy 1/2 on Win9x also makes me want to tear my face off with its software install and stability quirks but Audigy 2 in particular sounds a lot nicer than Live.
Reply 6 of 28, by swaaye
foey wrote:
Geforce 256 with a PIII will tear through Quake III 😀
This is highly dependent on resolution. I'd say 1024x768 is about the highest you'd want to run. But that's what you're gonna get with 1999 hardware.
Reply 7 of 28, by Darkman
thats actually a good 1999 setup , I would pick the Voodoo3 as the card of choice , even though the GF256 is faster, the Voodoo3 runs Glide games, very useful for UT99 too.
Quake 3 on the other hand will struggle a bit with the card at 1024X768.
Reply 8 of 28, by sunaiac
I would say :
- Athlon slot A
- 256 MB RAM
- GF 256 DDR
- Voodoo 2 SLI
- SB AWE 64 Gold
And yes, I have one like that 😁
R9 3900X/X470 Taichi/32GB 3600CL15/5700XT AE/Marantz PM7005
i7 980X/R9 290X/X-Fi titanium | FX-57/X1950XTX/Audigy 2ZS
Athlon 1000T Slot A/GeForce 3/AWE64G | K5 PR 200/ET6000/AWE32
Ppro 200 1M/Voodoo 3 2000/AWE 32 | iDX4 100/S3 864 VLB/SB16
Reply 9 of 28, by alexanrs
The Live doesn't sound very bad when using the rear outputs. Unfortunately the kXDrivers (which support swapping the front and rear outputs) doesn't do EAX. Is there any trick to swap the outputs on official drivers?
Reply 10 of 28, by obobskivich
It's cheating a bit, but: Pentium 4 Willamette and GeForce 2 Ultra. I like having a DVI output and not worrying too much about performance.
Reply 11 of 28, by swaaye
Unfortunately I don't think it's possible to swap outputs on the official drivers.
Reply 12 of 28, by carlostex
Why choose something so atrocious?
Reply 13 of 28, by leileilol
Scrapbudget-minded "high-end 1999" performance? 😀
Reply 14 of 28, by QBiN
I had a GF2-GTS in July of 2000 and wore it out... So I think a Gf-256 is perfectly era correct (came out in Oct.'99). Seeing how DirectX was pretty well in full swing by this time, I think you'll get more utility out of going with the nvidia card, IMHO.
Reply 15 of 28, by NJRoadfan
CMSS 3D "Stereo Surround" will mirror 2 channel audio to the rear speaker output. The older Live! drivers that came with AudioHQ seem to do it automatically. Of course, this won't work correctly with games expecting a proper multi-channel surround speaker setup.
Reply 16 of 28, by obobskivich
Similar performance to a top P3 at lower cost, and Quake 3 goes like the wind on NetBurst.
Reply 17 of 28, by Dreamer_of_the_past
From what you have I would pick:
Pentium III 733 MHz
3dfx Voodoo3
As previously mentioned this build needs either Aureal Vortex 2 or Creative Sound Blaster Live!
Reply 18 of 28, by carlostex
An Athlon XP would still be a much better choice, though i'm not sure if boards for that are easy or hard to find.
Reply 19 of 28, by alexanrs
But if you're going NetBurst on Socket 478, wouldn't a Northwood be a better choice?
