First post, by dogchainx
So I have a tower that has two floppy drives (3.5 and 5.25), and then a USB 1000 floppy emulator drive in it. Its getting to be a BIG PAIN switching around the cables between all three floppy drives.
Has anyone ever tried something like this (2/3rd the way down): http://www.seasip.info/VintagePC/floppies.html
Basically taking the active floppy line of the cable and making it switchable for two of the drives (Drive A, switch Drive A preferable).
If no one has, I might risk a few floppy drives and controller.
386DX-40MHz-8MB-540MB+428MB+Speedstar64@2MB+SoundBlaster Pro+MT-32/MKII
486DX2-66Mhz-16MB-4.3GB+SpeedStar64 VLB DRAM 2MB+AWE32/SB16+SCB-55
MY BLOG RETRO PC BLOG: https://bitbyted.wordpress.com/
Reply 1 of 2, by alexanrs
I'd feel more confortable adding another controller, or replacing the 3.5" drive with na IDE LS120 one...
Also, if you can find a switch with two "lines" I'd try switching both the drive select and motor lines.
Reply 2 of 2, by shock__
I've used computers with standard 4 drive shugart busses before (actually soldered them myself) - so why not?
Current Project: new GUS PnP compatible soundcard
[Z?]
