First post, by appollo147
Whenever I try to map the controls the joystick works great for movement so that is not the problem. The problem is with the buttons, the buttons do what I set them up to do but they also act as directional keys at the same time. For example, say I set the "A" button up as the fire button it also moves my character etc. to the left at the same time. The "B" button not only does what I mapped it to do but also moves the character to the right at the same time. Same thing with the "X" and "Y" buttons. I have tested the controller with several games, all with the same result. I have also tried setting the controls to "Auto", "2axis", "4axis" "Auto", "FSC", and "CH" all with the same results." Any help with this would be greatly appreciated.
