First post, by Stojke
Is there a way to make sure that Crystal CS4236B OPL3 clone gains accuracy when playing?
To my ear, Crystals FM clone is much better than the one found on CT3900 (CT1747) , the tones are more pleasant to the ear and the bass volume follows the rest of the tones, its not louder.
But, it is also missing a few tones some times, and occasionally sounds more crappy (bit i can tolerate that).
Its biggest advantage is that i can use LLSID with it, unlike with CT3900 where i get ear rape noises when i start the program and a large amount of noise, and the card i have (S-16FP/L) has very little noise.
Does any one know if it is possible to get all the sounds? Would be cool if i could disable playback channels and than just record the rest from hardware that has the right tones.
Also is there are CS4236 sound card with DOS compatible Coaxial Digital Out?
