First post, by SBeaver
Greetings 😀
An old-time favourite of mine is having a little problem.
The game in question is Colonization.
As stated in the game support comments by another user, sound fx don't work or work very badly.
The game still runs very well and the music is perfect, with almost any of the drivers that you can chose from in setup.
When trying sound fx setting, I tried the soundblasters and then all the others but none worked.
Sometimes I at least think there is a little sound but then the sound "collapses" into a screaming sound of static.
I think I have had such problems in real DOS mode too sometimes if I'm not misstaken but never this bad.
I have DOSBOX 0.61 and the latest version of colonization (the one that included a map editor that was available as a patch from microprose/infogames until a couple of years ago when they removed it)
On some configs I seem to get a lack of memory message from colonize setup but not always.
Any ideas? I'm running DOSBOX with the frontend at stock settings and have tried upping the memory a little and enabling cms, whatever that means.
(win2k sp4, intel p4 non-HT etc....)
Reply 2 of 12, by SBeaver
OK it seems simple enough, but where do I set the startup directory?
I don't want to get stuck with the keyboard compatibillity problems since I don't have a US keyboard.
Or maybe that bug was fixed.
Reply 6 of 12, by SBeaver
I thought I mentioned that in my first thread, I have tried all that are available.
This is the list:
COVOX Sound
Soundblaster (orig)
Soundblaster pro (early)
Soundblaster pro (later)
Pro audio spectrum
Pro audio spectrum plus/16
GOLD sound standard
I think the proaudio makes some kind of sound for example when I attack with a soldier but it is just a short thing that goes away and is replaced by something I thought sounded like waves or wind.
It's not how it should sound anyway.
All SB cards give screaming sounds.
I tried swapping irq and adress but that didn't help (changing both in dosbox and in this setup)
Reply 7 of 12, by Qbix
Rank DOSBox Author
DOSBox Author
Well I fear then there's nothing you can do.
(maybe disable ems)
If soundblaster pro (later) doesn't work (which is our main soundcard) then you're out of luck with sound on this game. Maybe in the future it will get better, but at the moment dosbox soundemulation and micropose colonizaion can't communicate properly.
Water flows down the stream
Reply 9 of 12, by robertmo
well.. it speeds up intro but instead the sound there is still just a loud noice.
I guess that it is the same problem as with other Microprose games: "Dragon Sphere" and "Return of the Phantom"
Dragonsphere
Reply 11 of 12, by SBeaver
Here is the version changes file for version 3.0 in file and another thing from the MPS that you can entertain yourself with if you get lonely (it goes in the game dir)
    col.zip
    10.74 KiB
    349 downloads
