Space Hulk Gravis
First post, by Jeep-Eep
I'm told this game can use Gravis Ultrasound; however, the instructions for enabling in http://www.gravisultrasound.com/files/documen … ation/GLIST.TXT are likely rubbish, as they mention replacing MIDI.ADV with GF1MIDI.ADV and space hulk doesn't even have that file type. What it does have is .DRV files. I assume the Gravis versions of that file would work, but I can't find them for the life of me. Would someone help here?
Reply 1 of 1, by hectic
No, the advice is good. Space Hulk uses the Miles Sound System drivers. You can copy the missing driver as a drop in replacement from other games of that era or AIL Version 2. Just rename it to midi.drv and put it into drv_dir.
I recommend using the mt32mpu.adv and configuring dosbox for using a MIDI device like bassmidi. The music will sound great.
