First post, by nemail
Hi
as far as I know, the AMD 386DX CPUs were exact copies of the Intel CPUs.
So I swapped out the Intel 386DX-33 in my 386 box with an AMD 386DX-40 and added an iit 4C87DLC-40 coprocessor to get the best performance possible.
I've enabled the coprocessor in the BIOS and I set the jumper "sync/async 387 frequency" to "sync" as both processors have 40MHz.
1st:
SPEEDSYS is showing 34MHz instead of 40MHz - my ASUS ISA-386C has no jumpers for frequency settings
2nd:
My CPU Benchmark result with the AMD 386DX-40 is lower (5.29) than the result with the Intel 386DX-33 (7.59).
Anyhow I was already curious about the result of the Intel 386DX-33 (7.59) because that is way higher than most if not all of you achieved in the "SPEEDSYS 386" thread.
Nonetheless, I'd like to max out the performance so if the Intel CPU is really faster for whatever reason I'll stick with it.
Do you have any idea what is happening here?
Thanks!
nemail
Reply 1 of 6, by sunaiac
Presence of a 387 divides speedsys score.
Real performance is not changed, don't worry.
edit : But changing a 33MHz CPU to a 40MHz one is not enough, 386MB set speed with some crystal I think ?
Not really my domain, I'm a 486 guy.
R9 3900X/X470 Taichi/32GB 3600CL15/5700XT AE/Marantz PM7005
i7 980X/R9 290X/X-Fi titanium | FX-57/X1950XTX/Audigy 2ZS
Athlon 1000T Slot A/GeForce 3/AWE64G | K5 PR 200/ET6000/AWE32
Ppro 200 1M/Voodoo 3 2000/AWE 32 | iDX4 100/S3 864 VLB/SB16
Reply 2 of 6, by HighTreason
I suspect Suniac is right about the performance.
If you have a 66MHz crystal, you could drop an 80MHz one in and you would see a 40MHz CPU clock... It might overclock the ISA or something a little though.
You could be adventurous and try to go faster if you wanted ;D
Reply 3 of 6, by nemail
ok thanks for the speedsys info - so the score gets divided by 2?
@crystal: crap - so i'd have to swap out the crystal to get 40mhz? i don't want to overclock anything, though...
Reply 4 of 6, by HighTreason
I can't speak for speedsys. But the crystal will be fairly trivial. At worst, your board will be dividing by 8 for the ISA clock, so you will get 5MHz instead of 4MHz, which is well within tolerance. I have ran ISA cards at over 20MHz without issue.
Reply 5 of 6, by smeezekitty
Uhh... isn't ISA 8 MHz and not 4?
Anyway, 10 MHz will work just fine with most ISA cards
Reply 6 of 6, by HighTreason
Eh? Yeah, oops. I forgot that the divisor refers to the crystal and not the CPU clock.
I think most ISA cards were probably made to run fine at 12MHz to be honest, given some boards seemingly yield this frequency no matter what.
My Shuttle 386 board has never had a problem with the divisor set to 8 (10MHz) anyway - though having speed jumpers, there are also ones to slow the ISA BUS to 8MHz.
