First post, by agent_js03
Hi all,
I have followed this forum:
Windows 3.1x DOSBox Guide
and have a working Windows 3.1 installed with the recommended S3 video driver and settings (version 1.70.04, 64k colors, 1024x768 res). The only problem that I am having is that when I open "control panel > desktop" it crashes dosbox. I am getting the following output:
XGA: Unhandled draw command 3
Segmentation fault (core dumped)
I am wondering if anyone has experienced this or if they have had different experience. I am using DosBox 0.74 on Ubuntu. Any help is appreciated.
Reply 1 of 6, by agent_js03
Sorry guys, I forgot to mention, I've tried different resolutions and also different video cards. I have had luck with other video cards (as well as the default VGA) but I was really wanting the s3 to be working because it has such a high potential resolution and color depth. I had some luck with the lowest settings for s3 as well, instead of crashing it just kind of freezes for a second. 😒
If noone else is able to help, I am thinking I might go ahead and try to write a patch for this myself.
Reply 3 of 6, by agent_js03
Thanks,
do any of those drivers support 1024x768 with 64k colors? I have tried the paradise as well as the et4000 and neither of them support it.
Reply 4 of 6, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
I think I had this with the standard s3 drivers I have in the guide. But first of all there is a still unresolved bug with OS X and no need for them actually to be in 64k 😉
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 5 of 6, by agent_js03
So when you say "try different drivers" do you mean try video cards other than S3, or do you mean try different S3 drivers? I have tried other cards and some of them, for example the et4000, work ok with windows 3.1, but the fonts are awful. S3 has the best performance but only has this bug. Are there other working drivers for S3?
