Default CPU speed is low
First post, by Munx
While it's not a big problem, something just keeps bugging me.
I have an AOpen AX6BC mobo in my vintage rig, and it underclocks all the CPUs I put in it by default. My Klamath P2 300 got UC'd to 233MHz, P3 550 to 350 MHz, also my P2 350 (just don't remember how much for this one). Every time I switch a CPU out I have to do a multiplier change. It's not much of an inconvenience, however I'm wondering if there might be a bigger underlying problem? Or is this just something I shouldn't really pay attention to?
My builds!
The Underdog - The budget K6
Reply 1 of 7, by alexanrs
Aren't Katmai P3s locked? So your board couldn't change the multiplier even if it wanted to. It could be that the board is just detecting (and reporting) the multiplier wrong, maybe because it is older than the CPUs? Anyway, you could test (with benchmarks) if your CPUs are actually being underclocked... perhaps only the ones with unlocked multipliers are.
Reply 2 of 7, by JayCeeBee64
Rank Retired
Retired
Sounds like some sort of "fail-safe" feature where the FSB and multiplier revert to a default setting when the BIOS detects a CPU change. It is a bit annoying, but harmless.
Ooohh, the pain......
Reply 3 of 7, by luckybob
+1
Check your battery, it might be low. Past that its actually a USEFUL feature if you are an overclocker. Considering its an AOpn board, I would venture a guess it does cater to overclocking.
Reply 4 of 7, by PhilsComputerLab
I have three of this board. Firstly there are a ton of revisions, but all of them act "funny" when you swap the processor frequently. I always do a full CMOS clear / reset when changing hardware on this board 😀
But otherwise it's a great board.
YouTube, Facebook, Website
Reply 5 of 7, by Munx
Thats good to know 😀 Guess I'll just have to remember to make some multiplier changes after cpu switches. Not planning to make any fow now anyway. Thaks for the info.
My builds!
Reply 6 of 7, by PhilsComputerLab
The board is jumperless, but has some BIOS options for FSB and whatnot. But it never hurts to do a CMOS clear 😀 I did remove all the slot brackets however, because one day I struggled removing a processor and got frustrated 😊
Reply 7 of 7, by buyerninety
Depends if the cpu was so-called 'multiplier locked'? also, what
Revision of the motherboard AX6BC (and maybe bios) you have...
