First post, by tdh777
Hi,
The link on the download page for Fedora Linux is broken. The Fedora project have restructured their website and I can't find dosbox anywhere there.
Can someone please point me in the direction of a Dosbox RPM suitable for Fedora Linux ?
Many thanks in advance,
Warren
Australia.
Reply 1 of 1, by dougdahl
Given that dosbox isn't being updated too often, you could always try using the system tools.
If you have yum running, you could use that from a terminal (as root)
yum install dosbox
Or you could use whatever software installer is called on your version of Fedora (on my older version it's Add/Remove Software under Administration programs, but there's probably another one.)
Failing that, especially if the Fedora links are bad, I've always liked going to http://www.rpmfind.net/linux/RPM/ and finding the right distro version and architecture. Still have to worry about dependencies, but it does tend to show where to find them.
