First post, by superfury
I've build a MIDI (.MID files) player to test my MPU-401 softsynth, but it seems to process the .MID file wrong. I'm getting strange results. Anyone knows what's going wrong?
Main thread routine running the MID file ():
extern uint_64 timing_pos; //Current timing position for MIDI speed playback!word MID_RUNNING = 0;HEADER_CHNK header;SDL_sem *MID_channel_Lock = NULL; //Our channel lock for counting running MIDI!byte *MID_data[100]; //Tempo and music track!TRACK_CHNK MID_tracks[100];void handleMIDIChannel(){word channel;channel = (word)getthreadparams(); //Gotten a channel?playMIDIStream(channel,MID_data[channel], &header, &MID_tracks[channel]); //Play the MIDI stream!SDL_SemWait(MID_channel_Lock);dolog("MID", "Channel %i finished", channel); //We're finished!--MID_RUNNING; //Done!SDL_SemPost(MID_channel_Lock);}//All used locks!extern SDL_sem *MIDLock;extern SDL_sem *MID_timing_pos_Lock;extern SDL_sem *MID_BPM_Lock;void dosoundtest(){memset(&MID_data, 0, sizeof(MID_data)); //Init data!memset(&MID_tracks, 0, sizeof(MID_tracks)); //Init tracks!word numchannels = 0;if ((numchannels = readMID("MPU.mid", &header, &MID_tracks[0], &MID_data[0], 100))){//Initialise our device!PORT_OUT_B(0x331, 0xFF); //Reset!PORT_OUT_B(0x331, 0x3F); //Kick to UART mode!updateMIDTimer(&header); //Update the timer!//Create the semaphore for the threads!MIDLock = SDL_CreateSemaphore(1);MID_timing_pos_Lock = SDL_CreateSemaphore(1);MID_BPM_Lock = SDL_CreateSemaphore(1);MID_channel_Lock = SDL_CreateSemaphore(1);//Now, start up all timers!word i;MID_RUNNING = numchannels; //Init to all running!for (i = 0; i < numchannels; i++){startThread(&handleMIDIChannel, "MIDI_STREAM", (void *)i, DEFAULT_PRIORITY); //Start a thread handling the output of the channel!}delay(10000); //Wait a bit to allow for initialisation (position 0) to run!startTimers(1);startTimers(0); //Start our timers!
byte running = 1; //Are we running?for (;;) //Wait to end!{delay(1000000); //Wait 1sec intervals!SDL_SemWait(MID_channel_Lock);if (!MID_RUNNING){running = 0; //Not running anymore!}SDL_SemPost(MID_channel_Lock);if (!running) break; //Not running anymore? Start quitting!}//Destroy semaphoreSDL_DestroySemaphore(MIDLock);SDL_DestroySemaphore(MID_timing_pos_Lock);SDL_DestroySemaphore(MID_BPM_Lock);SDL_DestroySemaphore(MID_channel_Lock);removetimer("MID_tempotimer"); //Clean up!freeMID(&MID_tracks[0], &MID_data[0], numchannels); //Free all channels!halt();exit(0);sleep();}}
MID.c: MIDI file read support and player of a channel:
#include "headers/types.h"#include "headers/support/zalloc.h" //Zalloc support!#include "headers/hardware/ports.h" //MPU support!#include "headers/emu/timers.h" //Timer support!#include "headers/support/mid.h" //Our own typedefs!#define MIDIHEADER_ID 0x6468544d#define MIDIHEADER_TRACK_ID 0x6b72544dword byteswap16(word value){return ((value & 0xFF) << 8) | ((value & 0xFF00) >> 8); //Byteswap!}uint_32 byteswap32(uint_32 value){return (byteswap16(value & 0xFFFF) << 8) | byteswap16((value & 0xFFFF0000) >> 16); //}uint_32 activetempo = 500000; //Current tempo!word readMID(char *filename, HEADER_CHNK *header, TRACK_CHNK *tracks, byte **channels, word maxchannels){FILE *f;TRACK_CHNK currenttrack;TRACK_CHNK *curtracks = tracks;word currenttrackn = 0; //Ammount of tracks loaded!uint_32 tracklength;byte *data;f = fopen(filename, "rb"); //Try to open!if (!f) return 0; //Error: file not found!if (fread(header, 1, sizeof(*header), f) != sizeof(*header)){fclose(f);return 0; //Error reading header!}if (header->Header != MIDIHEADER_ID){fclose(f);return 0; //Nothing!}if (byteswap32(header->header_length) != 6){fclose(f);return 0; //Nothing!}if (byteswap16(header->format)>1) //Not single/multiple tracks played simultaneously?{fclose(f);return 0; //Not single track!}nexttrack: //Read the next track!if (fread(¤ttrack, 1, sizeof(currenttrack), f) != sizeof(currenttrack)) //Error in track?{fclose(f);return 0; //Invalid track!}if (currenttrack.Header != MIDIHEADER_TRACK_ID) //Not a track ID?{
fclose(f);return 0; //Invalid track header!}if (!currenttrack.length) //No length?{fclose(f);return 0; //Invalid track length!}tracklength = byteswap32(currenttrack.length); //Calculate the length of the track!data = zalloc(tracklength+sizeof(uint_32),"MIDI_DATA"); //Allocate data and cursor!if (!data) //Ran out of memory?{fclose(f);return 0; //Ran out of memory!}if (fread(data+sizeof(uint_32), 1, tracklength, f) != tracklength) //Error reading data?{fclose(f);freez((void **)&data, tracklength+sizeof(uint_32), "MIDI_DATA");return 0; //Error reading data!}++currenttrackn; //Increase the number of tracks loaded!if (currenttrackn > maxchannels) //Limit broken?{freez((void **)&data, tracklength+sizeof(uint_32), "MIDI_DATA");return 0; //Limit broken: we can't store the file!}channels[currenttrackn - 1] = data; //Safe the pointer to the data!memcpy(tracks, ¤ttrack, sizeof(currenttrack)); //Copy track information!++tracks; //Next track!if (/*(byteswap16(header->format) > 0) &&*/ (currenttrackn<byteswap16(header->n))) //Format 1? Take all tracks!{goto nexttrack; //Next track to check!}/*if (!feof(f)) //Not @EOF when required?{fclose(f);freez((void **)data, byteswap32(currenttrack.length), "MIDI_DATA"); //Release current if there!return 0; //Incomplete file!}*/fclose(f);activetempo = 500000; //Default = 120BPM = 500000 microseconds/quarter note!return currenttrackn; //Give the result: the ammount of tracks loaded!}void freeMID(TRACK_CHNK *tracks, byte **channels, word numchannels){uint_32 channelnr;for (channelnr = 0; channelnr < numchannels; channelnr++){freez(&channels[channelnr], byteswap32(tracks[channelnr].length)+sizeof(uint_32), "MIDI_DATA"); //Try to free!}}byte consumeStream(byte *stream, TRACK_CHNK *track, byte *result){byte *streamdata = stream + sizeof(uint_32); //Start of the data!uint_32 *streampos = (uint_32 *)stream; //Position!if (!memprotect(streampos, 4, "MIDI_DATA")) return 0; //Error: Invalid stream!if (*streampos >= byteswap32(track->length)) return 0; //End of stream reached!if (!memprotect(&streamdata[*streampos], 1, "MIDI_DATA")) return 0; //Error: Invalid data!*result = streamdata[*streampos]; //Read the data!++(*streampos); //Increase pointer in the stream!return 1; //Consumed!}byte peekStream(byte *stream, TRACK_CHNK *track, byte *result){byte *streamdata = stream + sizeof(uint_32); //Start of the data!uint_32 *streampos = (uint_32 *)stream; //Position!if (!memprotect(streampos, 4, "MIDI_DATA")) return 0; //Error: Invalid stream!if (*streampos >= byteswap32(track->length)) return 0; //End of stream reached!if (!memprotect(&streamdata[*streampos], 1, "MIDI_DATA")) return 0; //Error: Invalid data!*result = streamdata[*streampos]; //Read the data!return 1; //Consumed!}byte read_VLV(byte *midi_stream, TRACK_CHNK *track, uint_32 *result){uint_32 temp = 0;byte curdata;if (!consumeStream(midi_stream, track, &curdata)) return 0; //Read first VLV failed?for (;;) //Process/read the VLV!{temp |= (curdata & 0x7F); //Add to length!if (!(curdata & 0x80)) break; //No byte to follow?temp <<= 7; //Make some room for the next byte!if (!consumeStream(midi_stream, track, &curdata)) return 0; //Read VLV failed?}*result = temp; //Give the result!return 1; //OK!}float calcfreq(uint_32 tempo, HEADER_CHNK *header){float PPQN, speed;byte frames;byte subframes; //Pulses per quarter note!word division;division = byteswap16(header->division); //Byte swap!if (division & 0x8000) //SMTPE?{frames = (float)((division >> 8)&0x7F); //Frames!subframes = (float)(division & 0xFF); //Subframes!speed = frames; //Default: we're the frames!if (subframes){//We don't use the tempo: our rate is fixed!frames *= subframes; //The result in subframes/second!}speed = frames; //Use (sub)frames!}else{//PPQN method!PPQN = (float)division; //Read PPQN!speed = (float)tempo; //Convert to speed!speed /= 1000000.0f; //Divide by 1 second!speed /= PPQN; //Divide to get the ticks per second!speed = 1.0f / speed; //Ammount per second!speed *= 0.5f; //Divide by 2 for slower speed!}//We're counting in ticks!return speed; //ticks per second!}//The protective semaphore for our flags!SDL_sem *MID_timing_pos_Lock = NULL; //Timing position lock!SDL_sem *MID_BPM_Lock = NULL; //BPM/Active tempo lock!uint_64 timing_pos = 0; //Current timing position!float BPM = 0.0f; //No BPM by default!void updateMIDTimer(HEADER_CHNK *header) //Request an update of our timer!{addtimer(calcfreq(activetempo, header), (Handler)&timing_pos, "MID_tempotimer", 0, 2, MID_timing_pos_Lock); //Add a counter timer!}//The protective semaphore for the hardware!SDL_sem *MIDLock = NULL;#define MIDI_ERROR(position) {error = position; goto abortMIDI;}void playMIDIStream(word channel, byte *midi_stream, HEADER_CHNK *header, TRACK_CHNK *track){byte curdata;//Metadata event!byte meta_type;uint_32 length; //Our metadata variable length!uint_64 play_pos = 0; //Current play position!uint_32 delta_time; //Delta time!byte last_command = 0; //Last executed command!int_32 error = 0; //Default: no error!for (;;) //Playing?{//First, timing information and timing itself!if (!read_VLV(midi_stream, track, &delta_time)) return; //Read VLV time index!play_pos += delta_time; //Add the delta time to the playing position!for (;;){//LockSDL_SemWait(MID_timing_pos_Lock);if (timing_pos >= play_pos){//UnlockSDL_SemPost(MID_timing_pos_Lock);break; //Arrived? Play!}//UnlockSDL_SemPost(MID_timing_pos_Lock);delay(0); //Wait for our tick!}if (!peekStream(midi_stream,track, &curdata)){return; //Failed to peek!}if (curdata == 0xFF) //System?{if (!consumeStream(midi_stream, track, &curdata)) return; //EOS!if (!consumeStream(midi_stream, track, &meta_type)) return; //Meta type failed? Give error!if (!read_VLV(midi_stream, track, &length)) return; //Error: unexpected EOS!switch (meta_type) //What event?{case 0x2F: //EOT?dolog("MID", "channel %i: EOT!", channel); //EOT reached!return; //End of track reached: done!case 0x51: //Set tempo?//LockSDL_SemWait(MID_BPM_Lock);removetimer("MID_tempotimer"); //Remove old timer!if (!consumeStream(midi_stream, track, &curdata)) return; //Tempo 1/3 failed?activetempo = curdata; //Final byte!activetempo <<= 8;if (!consumeStream(midi_stream, track, &curdata)) return; //Tempo 2/3 failed?activetempo |= curdata; //Final byte!activetempo <<= 8;if (!consumeStream(midi_stream, track, &curdata)) return; //Tempo 3/3 failed?activetempo |= curdata; //Final byte!//Tempo = us per quarter note!updateMIDTimer(header);dolog("MID", "channel %i: Set Tempo:%06X!", channel, activetempo);//UnlockSDL_SemPost(MID_BPM_Lock);break;default: //Unrecognised meta event? Skip it!dolog("MID", "Unrecognised meta type: %02X@Channel %i; Data length: %i", meta_type, channel,length); //Log the unrecognised metadata type!for (; length--;) //Process length bytes!{if (!consumeStream(midi_stream, track, &curdata)) return; //Skip failed?}break;}}else //Hardware?{//LockSDL_SemWait(MIDLock);if (curdata & 0x80) //Starting a new command?{dolog("MID", "Status@Channel %i=%02X", channel, curdata);if (!consumeStream(midi_stream, track, &curdata)) MIDI_ERROR(1) //EOS!last_command = curdata; //Save the last command!if (last_command != 0xF7) //Escaped continue isn't sent!{PORT_OUT_B(0x330, last_command); //Send the command!}}else{dolog("MID", "Continued status@Channel %i: %02X=>%02X",channel, last_command, curdata);if (last_command != 0xF7) //Escaped continue isn't used last?{PORT_OUT_B(0x330, last_command); //Repeat the status bytes: we don't know what the other channels do!}}//Process the data for the command!switch ((last_command >> 4) & 0xF) //What command to send data for?{case 0xF: //Special?switch (last_command & 0xF) //What subcommand are we sending?{case 0x0: //System exclusive?case 0x7: //Escaped continue?if (!read_VLV(midi_stream, track, &length)) MIDI_ERROR(2) //Error: unexpected EOS!for (; length--;) //Transmit the packet!{if (!consumeStream(midi_stream, track, &curdata)) MIDI_ERROR(3 + length) //EOS!PORT_OUT_B(0x330, curdata); //Send the byte!}break;case 0x1:case 0x3://1 byte follows!if (!consumeStream(midi_stream, track, &curdata)) MIDI_ERROR(2) //EOS!PORT_OUT_B(0x330, curdata); //Passthrough to MIDI!break;case 0x2://2 bytes follow!if (!consumeStream(midi_stream, track, &curdata)) MIDI_ERROR(2) //EOS!PORT_OUT_B(0x330, curdata); //Passthrough to MIDI!if (!consumeStream(midi_stream, track, &curdata)) MIDI_ERROR(3) //EOS!PORT_OUT_B(0x330, curdata); //Passthrough to MIDI!break;default: //Unknown special instruction?break; //Single byte instruction?}break;case 0x8: //Note off?case 0x9: //Note on?case 0xA: //Aftertouch?case 0xB: //Control change?case 0xE: //Pitch bend?//2 bytes follow!if (!consumeStream(midi_stream, track, &curdata)) MIDI_ERROR(2) //EOS!PORT_OUT_B(0x330, curdata); //Passthrough to MIDI!if (!consumeStream(midi_stream, track, &curdata)) MIDI_ERROR(3) //EOS!PORT_OUT_B(0x330, curdata); //Passthrough to MIDI!break;case 0xC: //Program change?case 0xD: //Channel pressure/aftertouch?//1 byte followsif (!consumeStream(midi_stream, track, &curdata)) MIDI_ERROR(2) //EOS!PORT_OUT_B(0x330, curdata); //Passthrough to MIDI!break;default: //Unknown data? We're sending directly to the hardware! We shouldn't be here!if (!consumeStream(midi_stream, track, &curdata)) MIDI_ERROR(2) //EOS!dolog("MID", "Warning: Unknown data detected@channel %i: passthrough to MIDI device: %02X!",channel,curdata);PORT_OUT_B(0x330, curdata); //Passthrough to MIDI!break;}abortMIDI://Unlockif (error){dolog("MID", "channel %i: Error @position %i during MID processing! Unexpected EOS? Last command: %02X, Current data: %02X",channel,error,last_command,curdata);SDL_SemPost(MIDLock); //Finish up!return; //Abort on error!}SDL_SemPost(MIDLock); //Finish: prepare for next command!}}}
playMIDIstream plays a MIDI stream, readMID reads a .MID file stream into memory for playback. freeMID releases a loaded .MID file stream from memory. PORT_OUT_B(port,data) sends data to the UART (MPU-401).
Anyone knows what's going wrong? Does my player have errors?
Edit: I've changed the container to include size limits instead of only memory protection. This way, data streams that are continuous in memory will be played correctly (instead of the streams starting the next stream track(s) when continuous in memory).
UniPCemu Git repository
UniPCemu for Android, Windows and PSP on itch.io
