Star Wars Pod Racer Slow?
First post, by ibm5155
Acording to this website:http://www.podracers.com/sysreqs.html
CPU: 166 MHz or faster CPU required; 200 MHz or faster recommended.
Memory: 32MB RAM required; 64MB recommended.
Video: 4MB PCI or AGP Direct 3D Graphics Accelerator required.
Sound: 16-bit sound card or better. PCI 3D sound cards supported.
So, I just don't get It, I have a Pentium MMX 233MHz (that's a bit higher than the recomended), 128mb sdram, a voodoo 3 3000 AGP and a Maxi Sound Game Theater 64 Isa.
The game runs soso well on low detailed areas but wow, some areas with alot of details drops the fps to 10 🙁 , so, is some stuff on my config making it lag or the guys who made that system req was a bit crazy with the testing ? xD
Maybe it's the isa sound card making it slow or voodoo 3 isn't that good with Direct3D games? D:
Reply 1 of 21, by Stiletto
Dang, that site is still online. It's 16 years old...
do the Fandango!" - Queen
Stiletto
Reply 2 of 21, by candle_86
given that the game was made in 1999, I'd imagine it would preform alot better on say a Pentium II/AMD K6-2 than a Pentium 1 class system
Reply 3 of 21, by Davros
could it be your soundcard being isa would be unlikely to support directsound
Reply 4 of 21, by ibm5155
I thought the same thing, but disabling sound ingame just gave me 3 to 4 fps, still not a huge help to reach 18 to 30fps...
Maybe a pci sound card with acelerated hardware (I think A3D?) would help on this case?
For me, it's like that first tomb raider that required Hardware T&L, without it, you must need a pentium IV 1,4GHz, but if your gpu supported it, you could play it fine over a pentium iii 1GHz.
Reply 5 of 21, by DOSfan1994
I have something that is making it more slow if you play this on Windows 9x on DOSbox.
You know when I was testing this game on Windows 95 by using DOSbox SVN. And I noticed during the race the CPU racers were going around circles in and out of the track I tried crashing and the game froze. And some times it happens when I don't crash.
I don't have any footage of the crashing and racers going around in circles part but here is the footage with no crashing. Ani keeps speeding down the track and the game freezes.
Please reply to me if anyone knows how to fix this issue I am going through.
https://www.youtube.com/watch?v=654gvfbMG0I
Reply 6 of 21, by leileilol
that has nothing to do with real system problems
AND DON'T USE DOSBOX FOR WIN9X GAMES
BTW have you ran dxdiag and disabled AGP texture acceleration?
long live PCem
Reply 7 of 21, by DOSfan1994
Yes.
Reply 8 of 21, by ibm5155
I heard that a Voodoo 2 would perform better on that system, maybe with that (if the game support it) I could get some extra fps? and would be a problem if I used the voodoo 2 + 3 together (the 3 for 2D)
Reply 9 of 21, by SpeedySPCFan
As far as I know it COULD work but probably not. It'd be better to pair the Voodoo 2 with a Trio64. But I'm not entirely sure, someone else here could probably give a better answer.
Musician & music gear/game reviewer.
MIDI hardware: JD-990, SC-55, SC-880, SD-90, VL70-m, Motif ES, Trinity, TS-10, Proteus 2000, XK-6, E6400U
Reply 10 of 21, by leileilol
You CAN use a Voodoo2 with a Voodoo3. I've done it before, installing V2 drivers first then V3 after. The Voodoo2 can still work if you supply its Glide dlls to certain games, however given that this is the Direct3D HAL Racer works with, that's not going to work AFAIK
and I cannot see any technical reason how a Voodoo3 could run Racer slower than V2. I highly suspect the performance issue is cache related, you should be seeing at least 20fps with those specs
long live PCem
Reply 11 of 21, by SpeedySPCFan
Huh, today I learned. Thanks!
Reply 12 of 21, by ibm5155
hmm I see.
Well, for me I only thinked it was weird, Like a 200MHz processor is recommended, so I with that I could play at least with 30fps almost all the time, unless they were talking about a pentium II 200MHz or a pentium pro I think (Or 20fps was fine on that year)...
About the CACHE, I can disable it to test, the motherboard has 1mb of l2 cache, with my pong game, there was a small percentage of performance increase.
it was like 1500fps without l2 cache and 1700fps with l2 cache (300fps without l1 and l2 cache).
The question about voodoo 2 is that it's older, and may could run faster... but acording to This video, it looks like the same performance as my computer.
Crap, why did I gave up of my pentium 3 1GHz, at least I saved the ati radeon 7200
Reply 13 of 21, by leileilol
Have you tried with less RAM i.e. 32mb? Could be a weird motherboard quirk or something
long live PCem
Reply 14 of 21, by idspispopd
@leileilol: That's a good point, the cacheable area might be restricted to 64MB so the machine might run faster with less memory. OTOH Intel VX/TX mainboards didn't have 1MB L2 cache IIRC.
Reply 15 of 21, by ibm5155
That's the motherboard : http://www.motherboards.org/mobot/motherboard … _d/MSI/MS-5184/
well, I would need to get a 64mb sdram first, or, take a k6-3+ and the problem would be solved...
Hmm can I limit the ram to 64mb even if it's a 128mb memory?
EDIT: Wow, actually, a K6-III is expencive 😳, I better try the 64mb sdram, so, should I get 2x32mb sram or 64mbsdram?
Reply 16 of 21, by idspispopd
MVP3 with 1MB L2 cache should cache 127MB in write back mode and 255MB in write through mode. That shouldn't be the problem. You could verify that with some diagnostic tool, for example CTCM (see http://www.heise.de/download/ctcm-111825.html or http://web.info.uvt.ro/~lcucu/htmldocs/toms/ctcm.html).
[EDIT] Could you do a benchmark with a more common game so we know if there really is an issue? Maybe Pod Racer is just CPU hungry.
{EDIT2] For a small boost you could switch to a higher FSB. A PMMX 233 should run fine at 2x100MHz, probably at 2.5x100MHz. (250MHz is only a 17MHz overclock.) This is assuming your RAM is at least PC100, but a suppose a 128MB module is faster than PC66.
Reply 17 of 21, by ibm5155
The ram came from my old pentium 3 1GHz machine, If I remember it was a PC133.
I Can do do a benchmark on Doom, Quake II, MDK, MDK2 (a bit slow, but I was expecting it since it's a "new" game), 3Dmark99.
For now I only remember quake 2 timedemo demo1 score (38fps with sound, 40fps without sound)...
It's a shame I lost my full Doom benchmark, I did a combo test testing cache L1/L2 on and off, and how much pc speaker, adlib, wavetable, sound blaster would inpact in framerate...
Reply 18 of 21, by idspispopd
The Q2 score sounds about right, a little bit on the low side. I can't find many comparisons, it seems that 38fps would be appropriate for a 200MHz MMX, but the settings and driver might be different. According to http://www.hwupgrade.it/articoli/skvideo/4/vo … oo-2_index.html you should see 44-45 fps.
I don't know if Doom would be too helpful.
Here is a comparison for FSB100: http://www.anandtech.com/show/200/4
Reply 19 of 21, by ibm5155
MMX 233 + voodoo 1 => Quake 2 640x480
hwupgrade.it : 30,2fps
anandtech.com : 19,9fps
Also I found this voodoo 2 benchmark over a vogon thread http://i9.photobucket.com/albums/a66/Amakusa6 … gaming_comp.gif
Well, I'll teste the 250MHz pentium MMX250 soon and compare the results with the 233
