Looking for a TV/Monitor
First post, by mr_bigmouth_502
For a while I've been wanting to replace my monitor with something that does 1080p, BUT, I've also been wanting something that has some of the same inputs a TV would have, so that I can kill two birds with one stone, and use the same screen for my PC as well as my consoles. The specs I'm looking at would be something like:
- 20-22" (anything bigger would defeat the purpose)
- Connections for HDMI, component, and VGA, as well as possibly DVI and S-video
- True 1080p resolution or greater (none of this fake 1080p compatible but really in between 1080p and 720p bullcrap)
- Decent scaling of 4:3 sources
Does anything like this even exist? 😜 Would I be better off getting a plain 1080p monitor with a separate converter for component?
Reply 1 of 9, by Sammy
i use a samsung led-tv.
I connect the pc via DVI to HDMI Cable
(tv has 2 hdmi ports)
also a vga port
and composite an rgb scart.
i am missing s-video.
but it has an dvb-t tuner.
and usb for watching videos from usb-stick.
Reply 2 of 9, by mr_bigmouth_502
Sammy wrote:
i use a samsung led-tv. […]
also a vga port
What model, if you can recall?
Reply 3 of 9, by kixs
I used to have this LG 22" 1080p:
http://www.lg.com/uk/monitors/lg-M227WDP-tv-monitor
It was great. I used it for Amiga 1200 over SCART connection. What annoyed me was 16:9 ratio so replaced it with an older model LG M228 16:10 that I still use for all my retro needs 😉
http://www.lg.com/uk/monitors/lg-M228WA-lcd-monitor
They both have 4:3 scaling but with 16:10 ratio you get a bit more height.
Reply 4 of 9, by mr_bigmouth_502
Right now, I'm trying to decide between this: http://www.bestbuy.ca/en-CA/product/insignia- … 95079120d22en02
and this: http://www.bhphotovideo.com/c/used/918932/sam … _1080p_led.html
What should I go with? I have a $25 gift card for Best Buy, so I'm tempted to go with the Insignia, but Samsung seems like a better brand.
Reply 5 of 9, by NJRoadfan
Is 24" too big? IF not, find a HP LP2475w, does everything you need. Its 1920x1200 16:10 aspect ratio, but scales 4:3 sources correctly. Has 2 DVI-I ports (both takes DVI or VGA input), Displayport, HDMI, component, composite, and S-Video along with a built in USB 2.0 hub. Another option is the Samsung Syncmaster 242MP, this one even has SCART RGB input for 15.75khz outputting machines.
Reply 6 of 9, by mr_bigmouth_502
The HP sounds great, my only question is, how well does it scale 16:9 content? Most consoles don't support 16:10, and for playing FPSs I'd like to be able to use 16:9 resolutions as it actually gives you a better FOV. Not really sure about the latter monitor, because pretty much nothing uses SCART here.
Reply 7 of 9, by obobskivich
I know Samsung made/makes a range of displays that offered what you want - I've seen a few of them in person, and as with most Samsung displays, they look nice. Vizio offers televisions in the 20-24" size range that will offer roughly what you want. Something like this guy: http://www.vizio.com/tvs/eseries/e241ib1.html
If used/old doesn't bother you - Dell used to include CVBS/S-Video support on a lot of their older UltraSharp monitors, which were generally good performers as well.
As far as 16:9 "giving you better FOV" - not always. That's only true if the game is Hor+; Vert- games will actually have a larger viewport on 16:10 (and yes, even today there are still Vert- games).
Reply 8 of 9, by NJRoadfan
It shows black bars on the top and bottom, otherwise 1:1 pixel mapping. The SCART input on the Samsungs is mostly for older game consoles and computers that output 15.75khz RGB video.
Reply 9 of 9, by ahendricks18
I've had the same old Sanyo LCD (although 720p I'm sure there are 1080 models). It has 2 component, one composite, VGA, 2 hdmi, and s video. it also has stereo output for a Home theater. I don't know if they have it in stores anymore (bought it in 2009) but I am sure if you look in Craigslist or classifieds and even in the recycling plants you can find a good one. I found a good older HD flat panel in the trash, and it works and I gave it to my friend. I also used my Tandy 1000 on my sanyo and it looks OK.
Main: AMD FX 6300 six core 3.5ghz (OC 4ghz)
16gb DDR3, Nvidia Geforce GT740 4gb Gfx card, running Win7 Ultimate x64
Linux: AMD Athlon 64 4000+, 1.5GB DDR, Nvidia Quadro FX1700 running Debian Jessie 8.4.0
