First post, by Munx
I've been trying to get WinQuake to work on my P100 machine for a couple days now, however every time I set the resolution to 640x480 or even 512x384 it crashes. Its seems to run fine in 640x480 windowed, but not full-screen. I tried forcing it through config.cfg and autoexec.cfg but the game seems to ignore everything and just goes to the default 320x200.
Running it on W95, a P100, 32MB RAM, 2MB Mach64 VT2 and a Voodoo which isn't being used since its software (GlQuake runs fine in 640x480 though).
Any idea on how I could force that res or what might be causing the crashes?
My builds!
The Underdog - The budget K6
Reply 1 of 5, by kanecvr
I bet it's the Mach64 drivers... I had the same issue once with a PCI ATi card ( 3D Rage? - don't remember) + Voodoo2 -> Quake 2 worked fine in Glide, but would crash at certain resolutions in software. I installed another set of drivers for the ATi card, installed DX6.1 and the issue went away.
Reply 2 of 5, by leileilol
You can list the modes detected (more modes than the VIdeo Modes section shows) with this command
vid_describemodes
(note the S at the end, there is already a vid_describemode which returns your current mode.)
and then you can set the mode with vid_mode and the corresponding number
Another switch to try is -dibonly which doesn't use DirectDraw (and is significantly faster/stable on more modern hardware like Geforces etc, because nvidia doesn't play well with MGL's buffer/palette stuff)
long live PCem
Reply 3 of 5, by Munx
Well the drivers I used were for the mach64 VT(1) chip, for a dell OEM machine, might have to try something else. Would this be the correct driver?
http://www.vogonsdrivers.com/getfile.php?file … 0&menustate=6,1
EDIT: nope. The specific card is 264vt2 and I cant find it on vogonsdrivers. Googling only brings up dead links and a bunch of shady websites asking me to download their "driver installer".
My builds!
Reply 4 of 5, by vlask
At vintage3D is original ati driver - http://www.vintage3d.org/driver.php. Use 3D Rage driver. Its the same version as was on ati site - http://web.archive.org/web/19980128132748/htt … 3drageI-VT.html
Not only mine graphics cards collection at http://www.vgamuseum.info
Reply 5 of 5, by Munx
Installed it, same stuff. I'm too tired to keep wrestling this card. Or maybe its W95, never had this problem with 98SE. I would just put another card in, but this is the only non-voodoo PCI card that have. Guess its time to find a new one.
Edit: also looking through the various benchmarks in vintage3d it seems that this card fails to launch almost every game that gets thrown at it.
My builds!
