First post, by jesolo
- l33t
I recently acquired an Asus PVI-486SP3 motherboard and inside the box I also found a folded piece of paper.
Upon unfolding it, I discoverd that it contained the jumper settings for the LED display of a PC case.
I've scanned it in and attached the file.
For those of you that are still fortunate enough to own a PC case with an LED display, and could never figure out which jumper settings to use, this might be helpful.
Please note: I haven't tried out these jumper settings myself and therefore am not sure whether these were "generic" across all PC cases. So, it might or might not work for you.
