Which is best to keep?
First post, by AllUrBaseRBelong2Us
Trying to downsize...
I have two Pentium III systems:
1) Pentium III 1.4Ghz Tualatin, Asus TUSL2-C board, 512MB (max it will take), Nvidia 6800GT AGP
2) Dual Pentium III 700Mhz Coppermine, Gigabyte GA-6BXD motherboard, 1GB (max it will take), Geforce MX400 AGP (board will only take 1x-2x cards)
Which would be the best one to hang on to?
Reply 1 of 11, by Skyscraper
Not a hard choice for me at all.
Reply 2 of 11, by oerk
Both are cool, but the Tualation is a lot more versatile.
Dual CPU systems don't help much with games of that era.
Reply 3 of 11, by Darkman
the Tualatin system , which will run Win9x era games the best (on the other hand the PIII 700 system's lack of speed wont help much for DOS games as its too fast anyway). the dual PIII is very cool , but not as useful.
Reply 4 of 11, by Skyscraper
There is always the third choice, you could throw her out! 😉
Reply 5 of 11, by silikone
Is it the S version of the Tualatin?
You could keep the second one and sell the first
Do not refrain from refusing to stop hindering yourself from the opposite of watching nothing other than that which is by no means porn.
Reply 6 of 11, by Jorpho
It all depends on what you want to do, doesn't it? If for some strange reason you need 1 GB of RAM and dual processors, then that's what you should keep. I for one can't really think of what you would need that for, though.
Reply 7 of 11, by TELEPACMAN
The Tualatin. You can allways keep/get a 700MHz coppermine cpu. That way if you need you can turn the tualatin system into a 700MHz one. It propabbly does not work the other way around right?
Reply 8 of 11, by tayyare
^^^This!.. 😈
GA-6VTXE PIII 1.4+512MB
Geforce4 Ti 4200 64MB
Diamond Monster 3D 12MB SLI
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
Reply 9 of 11, by Skyscraper
A witch a witch!
Only witchcraft can explain why we all agree on something...
Reply 10 of 11, by idspispopd
To offer a different opinion: GA-6BXD has two ISA slots, TUSL2-C has none. If you want to play DOS games (especially older ones) ISA is useful. Of course dual CPUs are totally useless for DOS (and Win9x), you'd have to use w2k/XP/Linux to use those.
The Tualatin is great for Win9x gaming, and you should also be able to slow it down through FSB (100 or 66 MHz) if the board supports that.
Reply 11 of 11, by tayyare
...or Windows NT!.. 😈
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
