First post, by hellzakk
Hi all, im trying to play the secret of monkey island from an original remastered cd but i cannot get the audio play.
If i play from the floppy version it work and if i run a downloaded version of the cd game from the cd-rom it work.
I have a CT2950 with a Wave Blaster and a dvd-rom.
Any hint?
Reply 1 of 23, by filipetolhuizen
Never heard about the remastered CD other than the Special Edition, but it's for Windows. Maybe it needs a command line.
Reply 3 of 23, by jesolo
From what it sounds like, the audio on this particular CD might actually be red book (CD Digital Audio) and not digital files (like wave or MIDI files) that are being played back.
Check whether you have a CD-ROM audio cable connected between your DVD-ROM drive and your sound card.
If so, check the volume level in your mixer control to ensure that the CD Audio level is high enough.
Reply 4 of 23, by collector
It may be like the version on Monkey Madness, if so it does have CDA tracks for the audio.
Reply 5 of 23, by hellzakk
jesolo was right i have connect the audio cable and installed the driver from the iso image sb16val_r1.iso downloaded from this site and now it's working but now there are a new problem...
in autoexec.bat the installation process add the following lines
SET SOUND=C:\SB16 SET BLASTER=A220 I10 D1 H5 P300 T6 SET MIDI=SYNTH:1 MAP:E SET CTCM=C:\CTCM C:\SB16\DIAGNOSE /S C:\SB16\MIXERSE […]
SET SOUND=C:\SB16
SET CTCM=C:\CTCM
C:\SB16\DIAGNOSE /S
C:\SB16\MIXERSET /P /Q
C:\CTCM\CTCU /S
and when i boot the pc it say
Starting MS-DOS 7.1... […]
Creative Plug and Play Configuration Manager (v1.04)
Copyright (C) Creative Technology Ltd., 1995-1996. All rights reserved.
Your system configuration has changed.
Please run Windows 95 to inizialize your system configuration.
Press any key to continue...
and when i hit a key the boot will continue and the sound work...
this output is give by ctcm... it's a wrong version?
EDIT : i've tried to delete
SET CTCM=C:\CTCM
C:\CTCM\CTCU /S
but the message still appear, so i dont know why this appen...
Reply 6 of 23, by PhilsComputerLab
Rank Hardware Mod
Hardware Mod
That's Windows 9x for you 😀
Mixing Windows with DOS can cause little issues like this.
A220 I10 D1 H5 P300 T6, is this the resource you configured under Windows? If not, go to device manager, and sort out the resources manually. Is this the only card in the system?
A220 I5 D1 H5 P330 is the default configuration. Once this is set in Windows. Reboot. Then shut down. Then boot Windows, go into MS-DOS mode and run diagnose on it's own. Let it update system settings. Shut down. And the resources should now match between Windows and MS-DOS mode.
If you want to learn a bit more how you can setup MS-DOS mode, check out some guides here: http://www.philscomputerlab.com/ms-dos-mode-tutorials.html
YouTube, Facebook, Website
Reply 8 of 23, by jesolo
MS-DOS 7.1 was bundled with Windows 95b and also with Windows 98.
I can't see how you could have installed it as a standalone operating system (unless it's some hacked version).
Try typing win at the command prompt and see whether Windows doesn't start up.
If that doesn't help, locate the CTPNP.CFG file (which is normally in your Windows directory) and manually edit the Sound Blaster settings under the SB16 section.
Reply 9 of 23, by skitters
SET SOUND=C:\SB16
SET CTCM=C:\CTCM
C:\SB16\DIAGNOSE /S
C:\CTCM\CTCU /S
Why the "I10" in the SET BLASTER line?
I've only seen I5 or I7 (IRQ 5 or 7) with an SB16.
Even with an SBLive in Windows, the SET BLASTER line would use I5 (IRQ 5) for DOS sound even though Windows put the main card on IRQ 10.
Reply 10 of 23, by jesolo
The default irq is 7 for older models (mostly the original Sound Blasters) and 5 for newer models.
However, nothing prevents you from choosing another irq, so long as it doesn't conflict with another device.
I'd stick with irq 5, unless you're playing very old games that expect the irq to be at 7.
Reply 11 of 23, by hellzakk
I have different dos and Windows but in this installation i have tried the dos 7.1 downloaded from internet so it's a stand-alone version.. anyway the problem seems to be a component like the creative plug and play configuration manager that is "set" for Windows. .?
Reply 12 of 23, by jesolo
My experience has been that the Creative Plug & Plug Configuration Manager (the one for DOS 6.22/Windows 3.1) don't work that well with MS-DOS 7.1 (it "thinks" you have Windows installed and then "forces" you to configure everything via Windows).
I suggest that, if you only want "pure" DOS, rather fall back on MS-DOS 6.22 and then follow the route of configuring your plug and play devices by using plug and play configuration managers.
Reply 14 of 23, by jesolo
CD-ROM audio is not dependent on IRQ or DMA settings of your sound card.
All that it does is to route the audio source via your sound card to the speaker or line out of your sound card.
Reply 16 of 23, by Tertz
try echo y|C:\CTCM\CTCU /S
but if the message appears in config.sys by DEVICE=C:\SB\CTCM\CTCM.EXE, and hence befor autoexec.bat, then it would not help. maybe there are command line settings for these utils switching on 'quite mode'.
DOSBox CPU Benchmark
Yamaha YMF7x4 Guide
Reply 18 of 23, by Tertz
hellzakk wrote:
yes because i've already tried to delete the 2 Line with ctcm in autoexec but the message still come
remove CTCM.EXE from config.sys - maybe the card will work without it
Yamaha YMF7x4 Guide
Reply 19 of 23, by PhilsComputerLab
Rank Hardware Mod
Hardware Mod
Ok so you're running MS-DOS 7.1, but without Windows.
Well Creative didn't plan for this. You're meant to set the resources in Windows.
Now there is modded CTCU, which is part of the CTCM package somewhere on VOGONS. It will skip the OS detection and lets you set resources.
Having said that, it's unusual for the card to get such resources in the first place. Disable any resources in BIOS you don't need. Like serial and printer. Do you have lots of other cards in the machine?
With an interrupt of 10 I feel that a lot of games might not work.
Also might be worth getting MS-DOS 6.22 instead or using proper Windows 98 SE + MS-DOS more.
