First post, by schlang
Hi, I try to run Unreal Tournament (GOTY Edition) on my K6-III+ at 400MHz (6* 66MHz) but I only have an average of 17fps in 800x600 which is imho far too low.
I am running Win98 with Direct3D, and with my system specs of 512MB RAM on a DFI MVP3 Chipset and a potent GeForce 4600 I would really expect more...
I haven't tried the Voodoo yet, but I don't want to play in 640x480 anyway.
Any ideas? Thanks.
Cheerss
PC#1: K6-III+ 400 | 512MB | Geforce4 | Voodoo1 | SB Live | AWE64 | GUS PNP Pro
PC#2: 486DX2-66 | 64MB | Riva128 | AWE64 | GUS PNP | PAS16
PC#3: 386DX-40 | 32MB | CL-GD5434 | SB Pro | GUS MAX | PAS16
Think you know your games music? Show us: viewtopic.php?f=5&t=37532
Reply 1 of 19, by F2bnp
You're trying to run Unreal Tournament using Direct3D and on a very slow CPU.
First off, you'd want to use the Glide renderer with a Voodoo card, preferably a Voodoo 3. Then, I suggest raising the FSB to 100MHz and if the CPU is not stable at 600MHz, try going lower, I've found 550 to be an almost 100% guarantee on these chips.
You'd be much better off with a Coppermine and a Voodoo5 or UTGLR for GeForce cards (a much better OpenGL renderer).
Reply 2 of 19, by schlang
I don't remember it being that demanding, but you are right - back in 1999 I was using a V2 SLI because GLIDE was just so much better.
Yet the UTGLR was a good idea so I can properly run UT on my main rig - thanks!
Reply 3 of 19, by Alex Virata
Hello there!
That game should be flying on your machine, it's quite strange to be getting such performance. I played it with a P2 450 Mhz, 256 SDRAM, Riva TNT at 1024x768 and everything at max!
Vsync some times kills the performance on Unreal Engine 1 games. My suggesting is to launch the game in troubleshoot mode, and run it in software mode. With that CPU it should run no problems (my first "Powerful" PC ran it only in this mode, P2 233 Mhz, 32 SDRAM, Ati Rage Pro 4 MB). If in software mode runs good, then the problem is in the graphic card.
May be you have AA activated on the nVidia control panel, or may be having a voodoo 1 affects the performance. May be even the sound cards! Even thou I don't think the sound cards should be making problems.
After writing all this, I realized that you solved your problem with UTGLR...
Regardless, the default Direct3D should be good enough, so your case will remain a mystery.
Cheers!
Reply 4 of 19, by dr.zeissler
Best option. Get a Voodoo3 and put a PII as CPU-Support. Then the game WILL fly.
Reply 5 of 19, by F2bnp
Alex Virata wrote:
Hello there! That game should be flying on your machine, it's quite strange to be getting such performance. I played it with a […]
Hello there!
Cheers!
Your memory must be fooling you, unless you enjoy playing the game at ~30fps with framerate dips. UE1 is insanely CPU intensive and a P2 450 is way faster than a K6-III+ 400. It's faster than a K6-III+ 600 even. On top of that, Direct 3D support in UE1 games is always rather terrible, glitchy and slow.
If you want a consistent 60fps, I'm not sure that even a Coppermine 1GHz will suffice, although it should be for the most part.
Reply 6 of 19, by PhilsComputerLab
Unreal (not UT) should be getting around 40 - 50 fps with a V2 and that processor. UT might be a bit more demanding though. Also, this is just the time-demo, which could be less demanding as well.
YouTube, Facebook, Website
Reply 7 of 19, by dr.zeissler
I just tested this on my PII-333/V3-3000. I get between 30-50FPS during gameplay. Sometimes it goes down to 17-20 but it stays playable.
Reply 8 of 19, by F2bnp
Yes, UT is certainly more demanding than Unreal, although I don't think I've ever seen this substantiated by anyone, it could be a cool project to work on.
Reply 9 of 19, by Alex Virata
F2bnp wrote:
Hello there!
Cheers!
At the time, I didn't know what "Frames Per Seconds" were, for me it was either playable or not.
However, I do remember finishing the first tournament with that PC and those settings.
Your claim that D3D on UE1 is terrible, glitchy and slow, is bit shocking to me. Today it is terrible, I admit, but on a Win98 or even WinXP it was butter smooth, and waaay better than that not finished OpenGl render, or any other render for that matter (I'm talking about the renders that came with the game).
Now, I looked on the net for more info about it, and it seems that you are right, BUT! My memory isn't failing me. Anantech and tomshardware are wrong! And I'll prove it. I'll undust few of my notebooks and run some benchmarks.
Until then, cheers!
Reply 10 of 19, by F2bnp
I didn't mean to offend you on the memory part. In all honesty, whatever's good enough for you. As long as I have the option, I will always opt for faster framerates and I don't consider 20-30 fps optimal in any way, playable maybe but it really depends on the game.
The truth of the matter is that UE1 created with mostly software rendering in mind and later on 3Dfx's Glide API. When Unreal (the first UE1 game) was first shipped it didn't offer support for Direct3D or OpenGL. These were added later on with patches and gradually improved upon, but even by mid 2000 with Deus Ex, you could see Voodoo 3 cards perform about as well as GeForce2 cards in UE1 games and Voodoo5 vastly surpassing such cards.
It is thanks to the efforts of gifted individuals that UE1 games can now be properly enjoyed without having to sacrifice IQ or performance, through the likes of UTGLR.
Ignoring the fact the CPU (PII 450) isn't terribly fast for UT to begin with, the TNT is just too slow to provide "butter smooth" performance at 1024x768 and with every details set at maximum. We're talking about a card that performance wise is closely matched with a single Voodoo2. A couple of Voodoo2 cards certainly isn't butter smooth for UT, although they're not half bad at all.
A Voodoo3 is much better overall with much better performance, especially when it comes to stuttering.
Again, I'm not saying you should have the best gear available to enjoy a game.
I just feel that since:
a)this is a game that you can play on your modern PC optimally with UTGLR or
b)you are going out of your way to buy vintage hardware with playing old videogames in mind
should you not strive to achieve the ultimate experience? In the second case, should you not go for the superior hardware, such as a Pentium III 733-1GHz (or even Tualatin if you can) + Voodoo3/5 or GeForce2/3/4/FX ?
Reply 11 of 19, by schlang
Is there UTGLR for Win9x also?
I am running UT now at my C2Q with UTGLR on Windows 8.1 x64 and it works very nice, however I experience random keyboard and mouse lockups 🙁
Reply 12 of 19, by F2bnp
That's weird, are you using wireless keyboard/mouse? They can be a pain sometimes!
UTGLR works on Win9x, just use an older version.
Reply 13 of 19, by schlang
I switched bus frequency to 100MHz and the K6 seems to run stable at 450MHz.
With 500MHz it won't even boot into DOS...
However I am running into stability problems regarding RAM with my 2x256MB configuration, they disappear if I only use 1x256MB.
Any suggestions?
PS: Haven't found a UTGLR for Win9x yet 🙁
Reply 14 of 19, by dr.zeissler
The K6-III+ was a nice project for me too, but after all a pentium-II is the better option.
Reply 15 of 19, by dr.zeissler
i forgot to mention that these frames are for 1024x768 and everything set to high.
Reply 16 of 19, by swaaye
There isn't a specific Win9x version. You just need to dig up an older version than the latest. I think 3.4 works.
It's downloadable in his news archive:
http://www.cwdohnal.com/utglr/newsarchive.html
Reply 17 of 19, by schlang
thx, with UTGLR 3.4 I get avg. 40fps with my GF4600 which is not that bad at all
Reply 18 of 19, by bimole
Hi,
I'm also experiencing weird FPS behaviour in Unreal in 32bit color mode.
I installed Unreal with the 226f patch.
My setup is as follows :
K6-2+ @ 550MHz
128MB RAM
ASUS P5A rev 1.04
GeForce 2MX 200 with 45.23 NVidia drivers
Windows 98SE with DirectX7.0a
No sound card installed
I get an average of 35FPS at 1280*720 in 16 bit mode while it drops at 11FPS in 32 bit mode...
Even in 320*240 I get a poor 24FPS in 32 bit mode while it reaches 40+FPS in 16 bit mode.
I have no such difference between 16bit and 32bit in other games like Quake II, MDK2 or even 3DMARK99 & 2000.
Any idea ?
Reply 19 of 19, by leonardo
bimole wrote on 2024-12-02, 20:02:
Hi, […]
Hi,
K6-2+ @ 550MHz
128MB RAM
ASUS P5A rev 1.04
Any idea ?
For one, Unreal and Unreal Tournament are different games - even if they share tech under the hood.
Secondly, the GeForce 2 MX comes in at least three varieties. The OG MX, MX200 and MX400. The MX200 is the castrated version, barely faster than a TNT2. One might say slower even. I don't think your system has the muscle for Unreal/UT in 32-bit, tbh.
My K6-III plays UT fine in 16-bit on a V3, and my PII 350 MHz could do 32-bit at 800x600 with a TNT2.
[Install Win95 like you were born in 1985!] on systems like this or this.
