Old Soyo Socket 7 Triton VX Help!
First post, by KitsuneFoxy
Hello everyone. I' found an old computer in our garage a few days ago. It boots up and works. But I cannot find out what the motherboard is.
I've narrowed it down to a Soyo 5vd2 or something, but the pictures don't match up to it.
It has an AT keyboard connector on the back, four simms at the top with 2 dimm slots below those. It uses a nickel rechargable battery.
I wanted to update the bios to the latest version, as far as i am aware it can run up to a AMD 266 or a Pentium 233. It has a Pentium 200mmx in it right now. with 128mb EDO ram. The motherboard supports USB In the bios, but it has no usb sockets on it.
If anyone can help me narrow this board down exactly, Id' be greatful, as i dont want toflash the wrong bios, or change a dip switch!
I've included a picture too.
If you can help me identify some of the cards too, that would also be great. I know one is a creative sound card, that's about it.
Reply 1 of 22, by ODwilly
The audio card is a Creative CT2960 Vibra 16, drivers should be readily available to download online. The video card is a Cirrus Logic card, the exact model number is underneath the words Cirrus Logic on the big black chip. The Phillips card is most likely a DVD decoder card of some kind, Sorry I can not help much there. Also I can not tell from your pictures what the model number of the motherboard is, sorry. You may be able to use the Bios string of numbers underneath "press F1 to continue" to identify it.
Reply 2 of 22, by JayCeeBee64
Rank Retired
Retired
According to the motherboard BIOS ID string, it's a Soyo 5VC. Here is a link to the 5VC2 to compare it with. Can't find an updated BIOS so far.
The Pinnacle card is a miro Video DRX, probably used for video capture.
The Cirrus Logic video card is a Prolink Computer MVGA-CL546XP (5464 video chip) and is limited to 2mb of memory. Here is a link with some basic info.
I have a Vibra16C CT2960. Fairly decent, clean but thin sound (no hardware mixer), has Creative CQM for FM synthesis (no OPL3). OK for basic use.
EDIT - Went to the Wayback Machine and found last updated BIOS and manual for the 5VC.
Ooohh, the pain......
Reply 3 of 22, by bjt
You will likely get better performance if you reduce the RAM to 64MB. USB will require a bracket to connect to a header on the motherboard, but be very careful with the pinout if you go down this route as it's a good way to blow up the board. This is very early USB 1.0 and might only work with USB sticks, printers etc.
Reply 4 of 22, by ODwilly
A pci USB 2.0 card would be a good option if you need USB.
Reply 5 of 22, by KitsuneFoxy
JayCeeBee64 wrote:
According to the motherboard BIOS ID string, it's a Soyo 5VC. Here is a link to the 5VC2 to compare it with. Can't find an updat […]
Just wanted to say thank you for the help!!!
That' is a huge huge help, and You guys trump my knowledge of things, Aha.
As for USB I'll probably go PCI USB 1.1 or something, as BJT pointed out, I don't want to go blowing up the board.
My Proposed upgrades for it are.
Raid 0 with 2 10GB drives.
98SE. (It's the most compatable)
a PCI Nvidia MX4000 64mb
And Probably USB at somepoint.
I'm not sure exactly what the capture card was used for, let alone know where the software/drivers for it exist. I'll do some googling once the parts arrive. :>
Thank you all. Will keep you posted.
Reply 6 of 22, by alexanrs
I'd change that graphics card for an MX440, since it supports older drivers and, therefore, might give you better performance and better compatibility with older stuff. You could always go Banshee/Voodoo³ as well.
Also, no reason to get an USB 1.1 card instead of a 2.0 one.
Reply 7 of 22, by KitsuneFoxy
Unfortunately i searched all over ebay for a PCI MX440. But there was'nt any. They were all aGP and the VX has no AGP slot.
Unfortunately the MX4000 was the only card i could get.
Howver i have a 433 AL440LX board, but it' wouldnt run in that either, since it's agp 1x/2z
Reply 8 of 22, by KitsuneFoxy
Hi all. I put the computer together today.
But i've an issue. It will not boot witht he PCI MX4000 plugged into the PCI slots.
But if i put the old cirrus one in it'll boot. I went in the bios and configgured it to snoop for PCI VGA and set the irqs all auto matical, but it just wont beep. I'm not sure what the problem is. The card is fine and more or less brand new.
Also i found out it IS a SY-5VC
Reply 9 of 22, by KitsuneFoxy
Oh, Also, Do you know what the commands are to boot the floppy with the bios and get it to start flashing? It's been a long time since i've had to do it with a floppy.
Reply 10 of 22, by calvin
As long as the boot order is configured, it will boot from the floppy first thing without intervention.
2xP2 450, 512 MB SDR, GeForce DDR, Asus P2B-D, Windows 2000
P4 2.6, 1 GB DDR1, Radeon 9600 Pro, P4P800, Windows XP
Alpha 21164, 512 MB, Permedia 2, KZPCM, AlphaPC 164, NT 4.0
Reply 11 of 22, by KitsuneFoxy
Yeah, managed to flash 5vC 0721 bios. Added some new options to the bios. But the PCI MX4000 plugged into the board will not boot. I tried the card in another motherboarrd and it works fine.
Sop i've no idea why it has an issue with this card.
The motherboard is PCI 2.1 complaint.
I'm just going to guess its a compatability issue. I'll get a Riva TNT2 or something 32mb,.
Reply 12 of 22, by KitsuneFoxy
I was curious, Could it be a Power Supply Issue? That it's not enough to power the card and the system entirely?
The PSU is only 200W.
?Could it be i need to get a better PSU? I could find an ATX to AT converter somewhere?
The PSU is a Vastec I also included a shot of the pci/isa slots, incase there was something notworthy there.
Reply 13 of 22, by bjt
Maybe a PCI compliance issue. VX is PCI 2.1 and the MX4000 may require PCI 2.2 or 2.3, or 3.3V.
Reply 14 of 22, by KitsuneFoxy
I guess that could be the reason, it is a dual notched card so it is 5v or 3.3. But as you suggested it might be a compliance issue. So I'll have to go with an older card, or fix up my Celeron 433. And use that if this other PCI card does not work. Ordered a PCI rival TNT 2. 32mb. I think that this would be able to run on the board. Its a Sparkle 5300 pci
Reply 15 of 22, by KitsuneFoxy
I'm also going to guess the old radeon 9250 wouldn't work due to the same thing. Will try it though.
Reply 16 of 22, by candle_86
I remember this kind of problem with a PCI FX5200 on an older machine, in the end I just bought a PCI Mx200 and it just worked
Reply 17 of 22, by ODwilly
O btw BJT was talking about the onboard usb 1.0 header not meeting the standard pinout when he was talking about blowing up the motherboard. If you connect usb ports to the onboard header that could happen 😀 if you get an old enough pci usb 2.0 card that meets the older pci compliance (like the issue you are having with a video card) then you will be fine! I can recommend a Belkin pci usb 2.0 card that uses an NEC chipset from personal experience with a p1 machine.
Reply 18 of 22, by KitsuneFoxy
well the bios added USB keyboard support, so it must have been updated in the bios or something., It probably is usb 1.0.
and the pinout matches a USB header i have though, it just slotted in.
USB 0.8 December 1994
USB 0.9 April 1995
USB 0.99 August 1995
USB 1.0 Release Candidate November 1995
USB 1.0 January 1996 Low Speed (1.5 Mbit/s), Full Speed (12 Mbit/s)
USB 1.1 August 1998
Reply 19 of 22, by KitsuneFoxy
Well i'm not having much bloody luck, honestly, Got everything set up including the raid. But now it wont seek from floppy, It doesnt even check the floppy even if i tell it to, It'll get stuck on Verifying DMI data, and stick there, But if i change it to CDrom it'll seek for the cdrom drive, then if there is no disk, it'll get stuck, it wont even seek the foppy drive when it has done before.. Tried three floppy drives and two cables.
Should i unset the Striping 0.5mb setting and then leave them as seperate drives then format them?
But i still don't understand why it wont seek the floppy drive. It'ss all connected properly and turned on. I've put the jumper on clear and unplugged it. So I hope it'll reset properly and work again.
