First post, by Turboman
I think I'm doing something wrong but I'm not sure. Is speedsys slow? I've noticed the last few times I tried it with a 386 and 486 when it's benchmarking it goes up 3% at a time and it just seems slow also when reading the memory it takes at least 2-3 mins to go all the way. Is this normal? On this board when I use cachechk it tells me it's fake cache and it also says Memory at 2mb all the way up to 16mb is running slow and I tried a 40mhz AMD and it displays 35mhz in speedsys when I tried a TI 40mhz it displays 13MHZ, when I tried the Intel 33DX it shows about the same score. The other thing I noticed is the TI cpu seems to get really hot to the touch is that unusual? to me the chipset seems to run hot as well after running for a few mins. This board is a GA-386ES, is that a typical speedsys score for this kind of 386? With this board I have to put a jumper on 39 on 2-3 which is the turbo switch I think to make it faster if I put the jumper at 1-2 or take it off it reads 26mhz instead of 35mhz. The bios on this is pretty plain not very much in there for settings.
http://museum.ttrk.ee/th99/m/E-H/30216.htm
Reply 1 of 1, by PhilsComputerLab
Speedsys is just one benchmark.
I've put together a benchmark floppy disk for 386 machines and some results to compare here: http://www.philscomputerlab.com/386-dos-benchmarks.html
Just follow the link. Should give you a better idea of where your machine sits.
YouTube, Facebook, Website
