First post, by chaossssssssssssss
Hi everybody!
I'm a new user here (yay, first post!). I got my first PC somewhere around 1997 or thereabouts, I was a C64 and Amiga user before. As far as I recollect, my first PC was a Pentium 166MMX (or maybe 200MMX, or maybe it was a non-MMX Pentium).
Besides all other retro stuff that already interests me, I just got a retro-DOS / Win98 obsession too 😉 The hoarder that I am, I think I already have all the required hardware needed for my build.
Here is the setup I envisioned, which more or less mirrors the PC I had back then:
- motherboard : MSI MS5170 - a nice Socket7 motherboard with 3xISA, 4xPCI, 2x72 pin memory, 2x168pin memory, and both AT and ATX power connectors
- CPU : Intel Pentium 200MMX
- RAM : currently, I have 16MB installed, hoping to find 128MB DIMM in one of my 'spare parts' boxes that I know works on this motherboard
- harddisk : I have quite a few , hoping something like 80GB will work, otherwise something smaller
- CDROM - I have some 24x speed CDROMs
- case : I have an OK small no-name mini-tower
- graphics : S3 Virge DX (it has four RAM chips soldered on, and four empty sockets - I'm guessing that means it has 2MB memory?)
- 3D graphics : 3dfx Voodoo2
- sound : Creative AWE64 Gold ISA
- MIDI : Roland SC-55
- network : 3com 3c905
- monitor : I'll probably use my old CRT Samsung Syncmaster 755DFX
I'm hoping to use this PC for some DOS and Windows98 gaming.
Does this seem like a good build? Would you change anything, anything sticks out?
I'm not sure about the Voodoo2, does it fit in a Pentium 1 build, or is it something you'd put in a newer PC build?
I have some other hardware from that era, would any of these be a better fit (or work better):
- graphics : S3 Trio64, ATI 3D Rage II + DVD
- sound : lots of PCI Soundblasters, like PCI128, Live!, Live! Digital, ...
- network : 3com 3c509 ISA and similar, some NE2000 compatible ISA and PCI cards (I think they are all Realtek)
Does using an ISA network card have any advantages over PCI? And for the soundcard, I guess it is better to stick with the ISA instead of PCI?
Thank you for any suggestions!
