First post, by whocares
I've successfully used DOSShark to find some codes in X-Wing such as unlimited missiles. My issue is that only the topmost code will work in the codelist. One of the posters in the DOSShark thread
also had this issue. He stated in one of his posts that he fixed it.
"All right! Thanks to the included source code, I was able to find the reason. There was a variable missing in the "inject_thread" part. It always used the first line instead of advancing to the next.
I compiled it again and now it works."
Can someone help me with figuring out what fix he made. I found "injector_thread" in one of the source files but I'm not really sure of what to do. I have some experience with c programming but can't figure out the change he made. If anyone can lead me in the right direction, it would be much appreciated. Thanks!
