First post, by brostenen
Hi all.
Are the SS7 and the Socket370 physically identical?
In other words, are they the same size in with and length?
Reply 1 of 7, by wbc
Yes, the width\length are same on S7 and S370, the latter has one\two (depends of side) extra inner pin "rings" and diffirent key orientation.
--wbcbz7
Reply 2 of 7, by tayyare
I'm not sure about the external sizes are different or not, but if you are asking this about the CPU cooler compatibility, I can say that they can use same CPU coolers with ease. My Socket 7 machines are using at the moment stock Intel PIII coolers.
GA-6VTXE PIII 1.4+512MB
Geforce4 Ti 4200 64MB
Diamond Monster 3D 12MB SLI
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
Reply 3 of 7, by PhilsComputerLab
Yes. But, many Super Socket 7 boards have capacitors very close to the socket. So larger coolers don't fit.
Reply 4 of 7, by HighTreason
Socket 462 is also roughly the same size (Slightly thinner) - I often use Athlon coolers on SS7 and S370 systems, though ones employing extra latches are incompatible.
Reply 5 of 7, by tayyare
It's exactly what I do. Two of my 370 rigs uses stock AMD Athlon 64 Coolers.
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
Reply 6 of 7, by candle_86
how did you fit an athlon 64 cooler onto anything smaller, its wider, alot wider than S5, S7, SS7, S370 and S462.
Reply 7 of 7, by tayyare
Sorry, it's my mistake. I meant "socket A" Athlons, not Athlon 64. 😊
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
