First post, by Neville
- Oldbie
"The Search for Freedom" is a Shareware RPG similar to "Ultima 4" developed by Howard Feldman. A copy can be found at https://archive.org/details/FREEV12
The problem I have is that I'm unable to finish the installation process. It seems to fail unless a FREEDOM folder is created first, and even then it fails after decompressing the Disk 1 files, asking the user to "remove the read only tab" on your floppy disks.
Also tried putting the install files on a different folder and mounting them as floppy.
