First post, by The Frederick
I'm trying to make a DOSBox shortcut that will run a game immediately, and I get that you use the game's directory as a parameter. Is there anyway way to have parameters for the game in this shortcut?
For example,
C:\DOXBox\dosbox.exe "C:\game\game.exe -debugmode"
Reply 1 of 3, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
yes, use a batch file and point to that instead of the exe.
(in case you don't know that, a batch file is a text file with the file ending *.bat (for example game.bat) with the necessary start commands (for example game.exe -debugmode) in there).
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 2 of 3, by The Frederick
Wow, I am really dense for asking this, because I've done that before with other stuff. Thanks mate.
