First post, by matte20
- Newbie
I am currently building a dual pentium2 333 system . the ram that i got with the board runs stable and passes memory tests . However it gives a SPD checksum error when checking either pci info or memory info on speedsys .The ram is three corsair cm654s64-10 64mb modules .
I have tested them individually and get the same results so i know its all three and not just one or two. They also cause speedsys to crash while saving test information . I've not run into this issue before ( at least that I can remember ) so looking for any info you guys have . I assume the ram is failing but i'd expect it to cause system instability ,so I'm a bit curious as to whats going on . I have enough 128mb modules to max it out but was hopping to run what it came with . pc133 seems wrong in a 66mhz bus system 🤣
I had to share , I've wanted to build a system like this since the hardware would have been new . I am enjoying it 😀
