First post, by rivillas
When tapping the Dosbox icon the installation starts but initial screen does not stay for more than a second; in Windows 7 PC there was no problem, however in my new Toshiba Encore 2 tablet it has been impossible. Help please!!
Reply 3 of 4, by Jorpho
I'm not sure if this refers to installation or to the actual running of DOSBox, but DOSBox (or more specifically the older version of SDL used by DOSBox) is known to have problems with tablets. The easiest solution is to plug in a mouse.
You should be able to find other threads about the issue by searching for "tablet".
