First post, by VileR
Attached appears to be a fixed-up diff.
However, compiling with mingw results in screen corruption on CLS *if* normal6x is used (no issue with 4x, 5x). Wonder what's up with that.
(Edit by Dominus: on request the patches have been split off the topic Re: normal4x, normal5x, one day ? and put into the patches forum)
    normal4x_5x_6x.diff
    10.87 KiB
    180 downloads
Reply 1 of 4, by VileR
Added feature: "normal2x" and "normal3x" now work in double-width/double-height modes too.
Normally the internal scalers have zero effect on:
  • CGA/EGA 640x200
  • Composite CGA
  • CGA/pcjr/tandy 80-column text (incl. "160x100" games like Round 42)
  • EGA/VGA 40-column text
  • various tweaked VGA modes (320x400, 360x480/350, etc.)
The updated patch allows simple 2x/3x scaling for all of the above. You have to specify the 'forced' parameter (e.g. "scaler=normal2x forced"); this is a deliberate choice, mainly for consistency's sake.
(Moderators: could this thread be moved to the patches section?)
    enh_normal_scalers.zip
    1.35 MiB
    119 downloads
    Win32 build
    enh_normal_scalers.diff
    16.95 KiB
    104 downloads
    Patch against DOSBox SVN r3850
Reply 2 of 4, by Qbix
Rank DOSBox Author
DOSBox Author
Sorry, removed the reply.
Not sure about which index to increase.
But the problem is that you are probably outside the writecache for normal6x
Water flows down the stream
Reply 3 of 4, by Qbix
Rank DOSBox Author
DOSBox Author
This might fix the problem you had with normal6x
Index: render_scalers.cpp
--- render_scalers.cpp (revision 4254)
+++ render_scalers.cpp (working copy)
@@ -30,9 +30,9 @@
Bitu Scaler_ChangedLineIndex;
static union {
- Bit32u b32 [4][SCALER_MAXWIDTH*3];
- Bit16u b16 [4][SCALER_MAXWIDTH*3];
- Bit8u b8 [4][SCALER_MAXWIDTH*3];
+ Bit32u b32 [5][SCALER_MAXWIDTH*3];
+ Bit16u b16 [5][SCALER_MAXWIDTH*3];
+ Bit8u b8 [5][SCALER_MAXWIDTH*3];
} scalerWriteCache;
//scalerFrameCache_t scalerFrameCache;
scalerSourceCache_t scalerSourceCache;
Reply 4 of 4, by Qbix
Rank DOSBox Author
DOSBox Author
the times 3 might be needed to increased as well (to times 6). But I have to double check that.
Seems to make sense to do that as well..
@@ -30,9 +30,9 @@
static union {
+ Bit32u b32 [5][SCALER_MAXWIDTH*6];
+ Bit16u b16 [5][SCALER_MAXWIDTH*6];
+ Bit8u b8 [5][SCALER_MAXWIDTH*6];
} scalerWriteCache;
