First post, by kanecvr
Hi guys. It's been a while since I posted here since my auto restoration project has been very demanding lately, but I wanted to share with you my latest "experiment"
I built a new 586 around a Biostar MB8433UUD-A UMC chipset socket 3 board, and I was surprised to see how speedy it is. With an am5x86-p75 overclocked to 160MHz, it runs as fast as most pentium systems - so I tought - why not throw in one of my Voodoo 2 cards for old time's sake. My first PC was a Cyrix 586 to witch I added a Voodoo 2 later - most glide games were quite playable (carmageddon, gl_quake) others not so much (quake 2 was a slideshow, and barely playable with the voodoo 2 card at 320x200).
So here are the results: http://youtu.be/ab6_eyiyCIo
Please keep in mind that the video is shot with my phone and it runs at ~20 fps... I'll replace it with a 30FPS one as soon as I have time.
It gets 18.4 to 20.3 average FPS in GL_Quake at 640x480 and feels quite playable. Unfortunately the engine won't start at 320x200 so I can't test it that way, but I remember it ran great at that resolution on my first PC. I'll try updating GL-Quake to 114 and installing the latest miniGL - maybe I can get it running at 320x200 that way.
The attachment IMG_20150621_041828.jpg is no longer available
Funny thing is, w/o the voodoo card, it gets 18-19 fps at 320x200 😀.
Sorry about the video quality - I'll shoot it again using my camera - running both software rendered quake and GL_quake.
Reply 1 of 5, by dr.zeissler
is it about the weak Floating-Point-Power of the am5x86?
this has no 3dnow-feature, so better option for this.
use a real pentium or pentium II or a K6 with 3dnow patch.
Reply 2 of 5, by Logistics
I know it has been a LONG TIME since I had the system I would have used to run Quake in 3D, but these framerates seem off. IIRC I had a Pentium 60 when I first started playing Quake, online. I recall that during this time I eagerly added a Voodoo1, which was leftover by a friend of mine who upgraded to a Voodoo2, then another for SLI. I recall that my game was playable, but was certainly not an amazing framerate--probably akin to the framerate YOU are getting, but again, that was with a P60 and V1. It doesn't seem reasonable that your framerate is so low. (IIRC, I would have been running 640x480 as well.)
Reply 3 of 5, by Artex
Maybe even a POD83? Too bad they have a hard timing running OC'd at @ 100Mhz due to undervolting them on the Socket 3 platform.
Reply 4 of 5, by swaaye
I've done this with a AMD 5x86 160 before. Those frame rates are about right. A Pentium Overdrive 83 would be much faster, around double perhaps.
Reply 5 of 5, by leileilol
because Voodoo2 can only go as low as 512x384, and to be honest, resolution isn't going to help you here. Might as well crank it up to 800x600 . 320x200 only started being supported on the VBanshee/V3
What will help is r_dynamic 0 and gl_flashblend 1 😀 That also goes for Quake2 which is a bit more cache heavy. Use low sound quality w/ performance for that one too
Also remember that the V2 has a performance edge over the V1 when it comes to multitexturing and it does make a small difference on a 486 class computer. 😀
My Voodoo2 is dead, but when it lived I did the same exact thing on the a similar AM5x86 160mhz setup and I also saw 17-28fps and it is indeed a more playable game than the software renderer. This was years ago because I wanted to debunk the "you cant use 486 with voodoo2 it require pentium" horseshit flying around the internet
Also Q3A can "run" on a 486 despite the Pentium MMX min requirement. 😀 😀 😀 😀 😀 😀 😀 😀 😀 😀 I almost want to try profile generation on that to see if it can squeeze a bit more out of it. Other ways may include stripping some of the lightgrid system to do Quake-like fixed direction light and integer-precise shaders
