First post, by Agent of the BSoD
- Member
This has been something that has been bothering me, and I'm not sure if this is normal, since this is the original Voodoo card (Diamond, in particular), or if my system is being weird about it.
The first thing I noticed after I installed it was that dxdiag no longer seems to work, instead, it just gives me a blue screen with something about fxmemmap. However, I can't even see this message until I switch the VGA cables as the Voodoo takes over and displays a solid color, usually blue, was magenta once. I also tried using the Glide2 and Glide3 diagnostic kit in Windows, using Glide2 obviously, and the same thing happens there.
The amusing thing to me is what Windows does after I install the drivers, using the latest reference ones. It says that "No driver files are required or have been loaded for this device." Now, if I ask Windows to find updated drivers for this device, it finds some, and using those, I can access dxdiag just fine, though the Voodoo doesn't show up. The diagnostic kit still fails as before. Using Windows' version of the drivers also seems to remove mm3dfx.drv, mm3dfx16.dll, and mm3dfx32.dll, since these aren't the latest drivers despite what it says. So I've gone back and forced it to use the reference drivers, at the cost of not being able to use dxdiag.
I have tested the Voodoo with Tomb Raider and it runs flawlessly there in Windows. (for some reason, Tomb Raider in real mode DOS crashes when it loads level 3, with both 3D patches and software mode, says that the game version doesn't match the file, but it will load level 3 if I disable sound completely)
My question is, is this normal for a Voodoo 1? I'm much more used to Voodoo 2s, as I have a couple of those. Maybe it's just because it's a much more limited device? It's not a big deal if it doesn't work in Windows like a D3D device, as I have other options for Windows 3D gaming, I'd just like it better if these issues were solvable so these blue screens stop bothering me.
Oh, and I'm using the built-in DirectX 6.1, as my Matrox Mystique 220 complains if anything higher is used.
Pentium MMX 233 | 64MB | FIC PA-2013 | Matrox Mystique 220 | ESS 1688 | Music Quest MPU Clone | Windows 95B
MT-32 | SC-55mkII, 88Pro, 8820 | SB16 CT2230
3DFX Voodoo 1&2 | S3 ViRGE GX2 | PowerVR PCX1&2 | Rendition Vérité V1000 | ATI 3D Rage Pro
