First post, by b_rros
Hi,
I'm trying to find two fans to replace the ones in my AGP Voodoo 5500. One of the fans isn't working and for now I just wish to replace the fans, I will keep the coolers. The problem is the only ones I can find with the right connectors (mini 3 pin???) are these ones:
http://www.ebay.com/itm/281487589329
They are the most expensive of the 40mm fans available on ebay 🙁 All the other 40mm fans I can find have different connectors that don't fit the ones in the card.
Anyone know where I can find some cheaper ones?
Thanks
b_rros
Reply 1 of 10, by tayyare
What about this one plus your cheaper fans plus a bit of soldering?
http://www.ebay.com/itm/JST-2-0mm-PH-3-Pin-Co … =item2a3ebf4f05
GA-6VTXE PIII 1.4+512MB
Geforce4 Ti 4200 64MB
Diamond Monster 3D 12MB SLI
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
Reply 2 of 10, by KT7AGuy
That's way too expensive for a little fan.
Try this one or this one from eBay instead. While I haven't personally tried them myself, they should fit the V5.
Reply 3 of 10, by tayyare
Or 3 of these:
http://www.ebay.com/itm/40mm-12V-DC-3-Pins-PC … %3D291374143675
and two of these:
http://www.ebay.com/itm/Desktop-Case-CPU-Chip … =item2c886e4dd3
And one of your motherboard's fan connectors. 😈
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
Reply 4 of 10, by Logistics
b_rros wrote:
Hi, […]
Hi,
Thanks
b_rros
You could try searching for the same fan by another seller on eBay:
http://www.ebay.com/itm/like/330786776347?lpid=82&chn=ps
Those ARE good fans--I'd buy them for my own if I had one.
Reply 5 of 10, by b_rros
@KT7AGuy @tayyare Thanks! But I don't have any soldering skills, I would probably just solder my fingers together 😀 And those connectors are different from the ones on the Voodoo card.
@Logistics That search brings down the price to 5 eur for fan, down from 15, plus 10 eur of shipping. That's 25 eur... Are they really that different from the chinese ones that are sold from 1 eur?
Reply 6 of 10, by blank001
You guys are crazy. I would give the 5500 the royal treatment. I cheap on a lot of things, but I never cheap on fans.
I plan to get two of these for it: http://www.ebay.com/itm/Noctua-A-Series-NF-A4 … =item43d20d6a30
Also, what is the point of powering the fan via the board? Why not just plug them straight into your motherboard?
_: K6-III+ 450apz@550, P5A-B, 128Mb CL2, Voodoo 5500 AGP, MX300, AWE64 Gold 32mb, SC-55v2.0
_: Pentium III 1400 S, TUSL2-C, 512Mb CL2, Voodoo 5500 AGP, MX300
Reply 10 of 10, by tayyare
I know, and It does not matter. The second option I suggested (3 of those and two of these) contains splitters for motherboard fan sockets. So you can connect the new fans directly to your mobo instead of the card itself.
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
