First post, by boxpressed
I love Norton Ghost 2003. I use it to clone hard drives and to save fresh and incremental installs on CD-R and DVD-R. The only problem I ever had with it occurs on my FIC VA-503+, an MVP3 board with a K6-2 350.
Everything works fine when saving and recovering from an image saved to a CD-R.
I can also backup to a DVD-R. However, when I try to boot from the DVD-R to recover, the system just hangs or gives me errors.
I don't have a problem recovering from DVD-R when I use a BX board or a KT133A board.
I'd like to use a DVD-R because I can then backup more than 1GB of data (Ghost compresses ~1GB of data to a CD-R).
Does anyone know if this is some kind of limitation of the MVP3 chipset or Award BIOS? I even use the same DVD-R drive (an LG) on all three systems, including the two others that work fine. I've tried different brands of DVD-R (including a DVD-RW), and I've both enabled/disabled UDMA on the DVD-R drive, which is the Secondary Master.
All help appreciated!
Reply 1 of 2, by tayyare
I had similar problems with my PIII machine in the recent past. It was based on a Gigabyte GA-6VXE7+ motherboard and was very insisted on accepting any DVD drive I connected to it as a CD Drive. I tired hard to find an external SCSI DVD Writer to solve this problem. This is not something I suggest though, it's expensive and problematic when considered as a solution.
As far as I know (I have a newer version like Ghost 14 or something), the ghost installation CD is already bootable. So you might boot the system from this CD and continue backup/recovery from there?
You can also look for a different software maybe? Acronis True Image has (I learned that recently 🤣) free versions downloadable from WD and Seagate support sites.
GA-6VTXE PIII 1.4+512MB
Geforce4 Ti 4200 64MB
Diamond Monster 3D 12MB SLI
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
Reply 2 of 2, by boxpressed
That's a good idea about booting from the installation CD. I could even try to boot off one of the backup CD-Rs and then swap it with the DVD-R and see what happens. May even try a different brand DVD-R drive.
