First post, by ge97aa
I'm using DOSBox 0.74 with the debugger. I would like to know how to start a program with the debugger active, while still passing command-line arguments to that program.
For example, let's say I want to run a program "program.exe" and pass it the command-line arguments "-arg1" and "-arg2". To run this program normally (without activating the debugger), I would simply type:
program.exe -arg1 -arg2
at the command line.
Now, I can start the program with the debugger active by typing
debug program.exe
at the command line, but this of course passes no command-line arguments to the program.
How would I start the program with the debugger active and still pass my command-line arguments to the program?
I have tried:
debug "program.exe -arg1 -arg2"
but this fails to start the program at all.
I have also tried:
debug program.exe -arg1 -arg2
but this does NOT pass "-arg1" and "-arg2" as command-line arguments to the program (presumably because these are treated as command-line arguments for "debug" rather than for "program.exe").
Is there a (simple) way to do what I'm asking?
