First post, by sf78
Anyone else run in to a problem with WC2 (or other games) not working with certain motherboards? I have an ICL 486 and Pentium that refuse to run with SB+Roland combination. If you select SB only, it works fine. I tried both floppy and CD-versions, but both hang at the "Expanded memory detected" screen. I used two different Roland MPU's and interface cards to makes sure, and all works fine on a AST 386 and a Digital Pentium. I think both ICL's use OPTi chipset, so it could be a problem with that.
This is quite close to what my ICL looks like:
https://ancientelectronics.wordpress.com/2015 … golite-dt48666/
