DOSBox Vsync
First post, by 33amaru
Hello, I would like to know if there is any method to activate VSYNC on DOSBox. I am playing a game, SIDELINE, but unfortunately I see a lot of screen tearing, I added a VSYNC feature on DOSBox configuration file, I was adjusting the VSYNC: of, on, host, etc., and nothing happens when I play the game, I really hate screen tearing. I also tried DOSBox SVN DAUM and I had no results, same thing like before, please help me.
Thank you
Roberto
Reply 2 of 10, by Stiletto
Moved.
do the Fandango!" - Queen
Stiletto
Reply 3 of 10, by 33amaru
Sorry, I am new here, I don't know where to go
Reply 5 of 10, by 33amaru
I am still getting the screen tearing and sounds skips a lot as well, I ran it on VGA at 70 Hz. Nothing changed.
Reply 6 of 10, by Tertz
The game appears to use 320x240, wich should be 60 Hz wich is standard for LCD. So it looks as other problem. I tryed it to run and did not notice tearings. Either they are few, or not at the game's beginning to check.
DOSBox CPU Benchmark
Yamaha YMF7x4 Guide
Reply 8 of 10, by 33amaru
I am playing the game with 60 Hz, on my TV or monitor and I am still getting tearings, that's on the regular DOSBox, but on DOSBox SVN Daum I don't get any tearing but takes more time to load game. Also when I start stages sounds skips at the beginning of each stage.
Reply 9 of 10, by Tertz
Regular DOSBox have not been updated for 5 years. You may try newer SVN. Also you may experiment with output= parameter in config, aspect=false, scaler= and other render parameters. While longer time to load a level is not a significant problem at all.
Yamaha YMF7x4 Guide
Reply 10 of 10, by 33amaru
I'm gonna keep trying, my only problems with the Regular DOSBox it's just the vsync, I have no problems with loading time and sound, on the SVN I get vsync, but sound skipping and I just try the game in other output and hand up.
