First post, by meljor
I just bought one but i don't know how to set the jumpers. Does anyone have the jp1 and jp2 settings for this adapter please?
Will use it with a p3 tualatin 1400@1050 or a celeron 1300 with Asus p3b-f (don't want to overclock this board).
Reply 1 of 7, by HighTreason
If you have a picture of link it is not loading for me.
The most common adapters I have seen are the PowerLeap ones, are they what you have? Or the Uniprocessor version.
Reply 2 of 7, by meljor
No, it is the upgradeware slot-t, it runs non-modded tualatins. Unfortunately there is no info on the adapter itself about the jumper and on the web i can't find the info.
I found this link but jumper pictures are gone...
http://web.archive.org/web/20080116043623/htt … slott/setup.htm
I hope someone here has the packaging it came with (or manual). On the back of the packaging are the jumper settings, but the only picture that shows this is to small and i can not read it.
    33.74 KiB
Reply 3 of 7, by gerwin
slott.zip in this topic holds the scan you are looking for:
(im)Possibilities wit Slotket CPU adapters?
The topic is old, I learned a lot more about Slot 1 / S370 / Slotkets since.
Reply 4 of 7, by HighTreason
Well... I sure goofed on that one. Probably because I have never heard of this model before and thought "Upgradeware" was just a term OP was using for... well... upgrade-ware.
Reply 6 of 7, by meljor
Great, thanx!
Reply 7 of 7, by doctoren
Above link is not working so just in case someone stumbles on this thread in the future. This is from the box of a v1.1 Slot-T but hopefully it applies to all revisions.
