First post, by KT7AGuy
Over the past 15 years, I've been slowly coming to the realization that aftermarket cooling for video cards is mostly unnecessary. Usually, the OEM coolers are just fine. Sure, the aftermarket stuff generally does a better job, but unless you're overclocking it doesn't matter much. However...
I've got this 6800GT AGP card that I've never really used very much. From what I've read, these and the 6800 Ultras run really hot. Additionally, I think these were the first generation of cards to suffer from BGA solder joint failures. As such, would it be in my best interests to slap on some aftermarket cooling? Phil is rather fond of these Chinese eBay coolers, so I would probably go with this. I would rather not have this card die prematurely.
What do you all think?
Reply 1 of 15, by Iris030380
The 6800 Ultra had a much deeper cooling solution than any 6800 GT I have seen. The Ultra was almost a dual slot card it was so thick. As far as I know, the GT's at stock speeds don't cook eggs. I have never owned an Ultra though. I've also put many 6800 GT's through their paces in benchmarking and playing COD 2 / Trackmania Nations / Doom III and never had any issues with heat in the long term. I have about 5 6800 GT's from various manufacturers such as Asus, Leadtek and XFX and they are all still working perfectly.
I5-2500K @ 4.0Ghz + R9 290 + 8GB DDR3 1333 :: I3-540 @ 4.2 GHZ + 6870 4GB DDR3 2000 :: E6300 @ 2.7 GHZ + 1950XTX 2GB DDR2 800 :: A64 3700 + 1950PRO AGP 2GB DDR400 :: K63+ @ 550MHZ + V2 SLI 256 PC133:: P200 + MYSTIQUE / 3Dfx 128 PC66
Reply 2 of 15, by swaaye
I've had one of those linked Chinese coolers on a 6800 Ultra for years and it works fine. It will hit 80C but that is a fairly typical load temperature for the 6800 cards. It's much quieter than the stock cooler (it's basically inaudible) and runs about the same temperature range.
I think 6800 is still a lead solder card. I don't see a ROHS label anywhere.
According to this testing at XBit, the 6800 Ultra consumes about 20W more power than a 6800GT. Considering that, I think the Chinese cooler would do very well on a GT.
Reply 3 of 15, by GeorgeMan
Here is ULTRA's stock cooler.
Pretty damn solid I'd say! Pure copper, also.
But doesn't help. Here in Greece, I have an avg room temp of 29°C on summer, and the card's temperature doesn't drop below 58°C while... idle.
During gaming, it stays in the pretty ok levels of ~75°C.
Keep in mind that my card is Gainward OC version, so it's slighlty overclocked by default. Also, these temps are with brand new thermal paste.
Acer Helios Neo 16 | i7-13700HX | 64G DDR5 | RTX 4070M | 32" AOC 75Hz 2K IPS + 17" DEC CRT 1024x768 @ 85Hz
Win11 + Virtualization => Emudeck @consoles | pcem @DOS~Win95 | Virtualbox @Win98SE & softGPU | VMware @2K&XP | ΕΧΟDΟS
Reply 4 of 15, by swaaye
My Ultra had a taller aluminum heat sink on the GPU. There are pics of the variations on Google images of course....
Reply 5 of 15, by meljor
After market coolers can do a very good job at getting the gpu temp down. However, they do not always provide the best cooling for the vrm's and they get really hot.
I had this problem with a x1950xt card years ago. It came down 20 degrees celcius on the gpu but it became unstable because vrm temps went up. Had to add a fan blowing over them.
Reply 6 of 15, by swaaye
Fortunately the 6800 cards have nice separate RAM and VRM heatsinks that can continue to be used.
Reply 7 of 15, by meljor
Yes, the x1950 had these as well. But the stock cooler blew the air over it where the aftermarket cooler didn't, at least not enough. I don't know how hot the 6800 vrm's get.
I have an 6800 ultra with stock cooling. It gets the job done and i don't overclock the card.
Reply 8 of 15, by nforce4max
@GeorgeMan
I know how it feels about summer, can be pretty brutal in the southern US but thankfully not near as bad as Australia even with the humidity.
Reply 9 of 15, by PhilsComputerLab
Hmm I think using that eBay cooler on a 6800GT is brave 🤣
It works well on a 5950 Ultra, but even that is beyond what the product description claim as supported. I believe it gets to maybe 50c to 60c, which is pretty good. I haven't seen anything "beefier" for that price though, so there aren't a lot of options really.
Removing the stock cooler, cleaning everything, fresh paste, maybe lubricate the motor. Should sort things out.
YouTube, Facebook, Website
Reply 10 of 15, by swaaye
According to the XBit Labs article, 5950 Ultra is similar to 6800 Ultra and consumes about 20W more load power than a 6800GT. 55W vs. 75W cards.
But yeah there certainly are much more effective cooling options out there. I'm surprised what these $5 Chinese things can handle though!
Reply 12 of 15, by PhilsComputerLab
Can't beat the value, no doubt. I have to admit that I only ran these on an open test bench. So likely the 5950 Ultra would be quite a bit hotter inside a case...
Reply 13 of 15, by GeorgeMan
It's as tall a dual slot card can be. It's just the angle of the photo that doesn't help in showing that. 😀
Reply 14 of 15, by maverick85
My 6800GT came with an Arctic Cooling Silencer as stock 😉
ASRock 98
Win98SE Desktop
ASRock
Intel Core 2 Duo E8400 3.0GHz
1 x 512MB 667 MHz DDR2
Soundblaster SB0100 + Altec Lansing ADA885
ATi Radeon X800XT 256MB GDDR3
1 x SATA 120GB HDD
1 x SATA DVD-RW
Reply 15 of 15, by KT7AGuy
Thank you everybody for your replies! For now, I'm going to stick with the stock cooling on my 6800GT. Since I don't intend to overclock it, I think it should be sufficient once I clean it up and reapply TIM.
While pondering my 6800GT and this thread, I was messing around with one of my other systems and noticed that the fan on my AGP 7900GS wasn't always spinning up at boot. It wasn't seized up; it just sometimes failed to start. One of the copper coils inside the fan looked a bit burnt, so I considered my options. Unfortunately, the AGP 7900GS uses a very non-standard layout and aftermarket options are extremely limited. Of most concern is the position of the HSI bridge chip. There is just no good way of cooling that thing with an aftermarket solution.
Rather than spend money and turn this into Dr. Frankenstein's own video card, I decided to just cut out the stock fan, enlarge the opening with a dremel, and bolt/epoxy a 50mm fan on top of it. It doesn't perform any better than the original stock cooler and it now takes up two slots inside the PC, but at least I didn't have to spend any cash to fix it. From what I've read, the GF7 series cards had somewhat high failure rates, so I'd rather not make any further investments in this card.
