First post, by mccorkled
Thanks to all the people that are willing to help people, I have learned a lot in the few threads I have posted. I have another issue that just came up when going through all my old games and installing them.
When I run the setup.exe through windows 3.11 everything works fine and dandy. The problem is that I am keeping all my games in a separate location. I moved the folder to where all my other games are and then setup the autoexec as follows...
(Z is my server, it is not causing this issue, ALL my other games work fine)
[autoexec]# Lines in this section will be run at startup.mount c "Z:\Hyperspin\Emulators\Microsoft MS-DOS\Windows 3.1"mount D "Z:\Hyperspin\Emulators\Microsoft MS-DOS\ROMS\Bermuda Syndrome"c:cd windowswin c:\windows\runexit d:\scn\bermuda.exe
The bermuda.exe file is located in the scn folder after the install.
Windows 3.11 launches fine and then I get this error,
followed by this...
followed by this...
I also tried this autoexec,
[autoexec]# Lines in this section will be run at startup.imgmount D "Z:\Hyperspin\Emulators\Microsoft MS-DOS\ROMS\Bermuda Syndrome\CD Image\Bermuda Syndrome.iso" -t cdrommount c "Z:\Hyperspin\Emulators\Microsoft MS-DOS\Windows 3.1"mount D "Z:\Hyperspin\Emulators\Microsoft MS-DOS\ROMS\Bermuda Syndrome"c:cd windowswin c:\windows\runexit d:\scn\bermuda.exe
to no avail. From what I understand, the CD needs to be in the drive when you play the game, even though a FULL install copies all of the CD files over to the HDD. I thought mounting the CD would work but it did not.
Thanks! 😀
