First post, by catchaserguns
I recently upgraded my video card and now my characters are practically invisible. I'm running a 2,6ghz Dual Core with 2G of ram and an ATI HD 6670 1GB video memory. I'm running XP SP3. Can someone offer me a solution on this? I really want play this game.
Reply 1 of 7, by Jorpho
So, patch the game? Install up-to-date video drivers?
Also, you might want to fix the spelling of your subject line.
Reply 2 of 7, by catchaserguns
I did patch the game and I have the latest video drivers and the characters are barely perceivable.
Reply 3 of 7, by leileilol
In case you give up for some reason, I hope you are aware of the horror stories behind that particular game's uninstall routine.
long live PCem
Debian's fucked
Reply 4 of 7, by catchaserguns
I've used the Microsoft Application Compatibility Tool and the it still shows up as ghosts but more defined. Any other suggestion will be of great help.
Reply 5 of 7, by Dagar
I remember playing this one a while back and with newer drivers (I have a Nvidia card) and I had to disable DirectDraw acceleration.
You can do that by selecting:
Start/Run....then type DXDIAG ---> Display/Disable DirectDraw acceleration
Don't forget to turn DirectDraw acceleration back ON when finished.
Reply 6 of 7, by catchaserguns
I tested using you recommendations and it worked.
Reply 7 of 7, by twiz11
Kill the explorer.exe by way of batch file
@ECHO OFF
TASKKILL /F /IM explorer.exe
pool of radiance exe
START C:\Windows\explorer.exe
