First post, by tognin
Hi!
I'm trying to make a DOS system to play all my childhood games but I'm having some issues with older games. My configuration is the following:
- Pentium MMX166 mhz
- 64MB RAM
- Freedos
- ISA Sound Blaster AWE64
- S3 virge DX
I'm getting sound in modern DOS games like DreamWeb, Quake... but I'm tryng to make Monkey Island I&II to sound but I'm not capable of. F1GP has no sound too nor Alien Breed (This freezes when I'm trynig to configure it)
¿Why is this happening? ¿It is maybe an PnP issue? ¿Must I configure something in BIOS?
Thanks, and forgive my bad English 😀
Reply 1 of 11, by PhilsComputerLab
How did you install the Sound Blaster drivers?
YouTube, Facebook, Website
Reply 2 of 11, by tognin
I'm using the CTCM utility. It sets de SB environment wihout issues.
Regards
Reply 3 of 11, by PhilsComputerLab
Yes, but how did you install it?
Reply 5 of 11, by Stiletto
Moved.
do the Fandango!" - Queen
Stiletto
Reply 6 of 11, by tognin
Ah, OK thanks for moving to the right place.
I load CTCM in Autoexec. This is the only thing I did and some games works, but some other dont.
thanks
Reply 7 of 11, by PeterLI
Reply 8 of 11, by PhilsComputerLab
Well, that's why I'm asking 😀
You need CTCMBBS and SBBASIC from the creative site. Extract both into folders, then run INSTALL.EXE from the SBBASIC folder. It will ask you to enter the path to CTCM, so enter the path to the CTCMBBS folder.
I've done a video guide if this was too brief:
How to install ISA Plug and Play Sound Blaster in DOS
Reply 9 of 11, by tognin
OK, thank you very much.
I will try it and post the results.
Thanks again 😀
Regards
Reply 10 of 11, by tognin
I Installed the SB16basic and everything went fine.
thank you very much!
See you!
Reply 11 of 11, by PhilsComputerLab
Good to hear!
